Sponsored by:
Sponsored by: CARiD
idle issue ...
Old Jun 9, 2013 | 10:43 PM
Evolution.X's Avatar
idle issue ...
Hey , its my first post here
am a new evo fan
i bought an gsr evo 10
it was amazing till i had this issue
the idel is good when the AC is off
but after turning AC on the idle going down too less than 500 rpm then going up several times till i turn the AC off
the car moods is:
- turbo smart Mitsubishi Dual Port bov
- down pipe
- intake
- exhaust
and i cleaned the maf , then change it , with out any different
what do u think guys ?
Old Jun 9, 2013 | 10:46 PM
mert34's Avatar
What kind of intake does it have and how high does the idle actually go when it goes up?
Old Jun 9, 2013 | 11:00 PM
k&n intake
almost 200-1000 rpm
Old Jun 10, 2013 | 12:49 AM
goCJgoCJgo's Avatar
Check your relays. I had to replace mine cause it had irratic idle. SSP sales a relay package. Look it up.
Old Jun 10, 2013 | 08:39 AM
Jerm6908's Avatar
Does the intake have a heat shield i kno my cobb SF intake dont an it messes with my Idle because of the fans kicking in
Old Jun 10, 2013 | 08:51 AM
xEvilEvoX's Avatar
My stock 2013 does the same thing. It jumps from 750 to 1k rpms then go back down once in a while when the AC is on.
Old Jun 10, 2013 | 09:29 AM
Slyy's Avatar
If your intake has the heat shield then that's normal. When the A/C kicks in the RPM's jump around a bit. I notice it happens when the Fans kick in.
Old Jun 10, 2013 | 02:45 PM
goCJgoCJgo's Avatar
K&N intake usually comes with a heat shield unless he bought it used. Or he might be using the drop in filter.
Old Jun 12, 2013 | 07:01 AM
ThePrecisionIma's Avatar
Anyone know if this issue is lessened with either the AMS or ETS intake? Or does it become exaggerated over stock?
Old Jun 12, 2013 | 12:11 PM
EvolutionIX219's Avatar
My IX does this as well. When the RPM's get low enough the oil sensor flashed on.
Old Jun 13, 2013 | 05:10 AM
I found the problem !! I gust cleaned the air filter and changed the AC filter !!
And now every thing is good
Old Jun 13, 2013 | 09:10 AM
Jake.barratt's Avatar
Good to know it was a quick and easy fix!
Old Jun 23, 2013 | 07:14 AM
arievox's Avatar
Mine did the same thing. It was a vac line issue though.
silentkiller
AEM EMS
Jan 22, 2014 06:06 AM
fabcas311
10
Jun 30, 2011 12:39 PM
Darewood
Apr 20, 2011 03:26 AM
harris81
AEM EMS
15
Jul 23, 2010 09:48 AM
davemiro
Lancer Troubleshooting
43
Jul 1, 2006 09:41 AM
