Sponsored by:
Sponsored by: CARiD
ETS High Flow Cat vs ETS Test Pipe
Old Jun 24, 2013 | 05:14 PM
Nobeam's Avatar
I'm putting a EST quiet V2 on my stock Evo 13 w\grim3 and pro tuned.
but I can't make up my mind if i should go HFC or test pipe.
Is performance and sound the same?
Old Jun 24, 2013 | 05:56 PM
Kendogg's Avatar
My understanding is the test pipe will give you a little more hp but will be louder. The HFC will give you a little less hp but not be as loud. Don't quote me on this though
Old Jun 24, 2013 | 07:06 PM
Baller4u2nv's Avatar
this is guy is right. And the ETS Quiet Exhaust is NOT "quiet" with the test pipe. Trust me. If you don't want anything loud, don't get the Testpipe
Old Jun 25, 2013 | 12:34 AM
alex the great's Avatar
Instead of the the HFC, you should consider a resonated test pipe instead. Same performance as a normal test pipe ( both are straight through inside) but the the car won't be as loud. I just changed my ETS tp for the AMS resonated tp due to the drone.
Pic of the ams resonated tp
Old Jun 25, 2013 | 08:00 AM
FearDavid0586's Avatar
If you swap from TP to resonated TP do you need to get retuned?
Old Jun 25, 2013 | 09:29 AM
tkromer's Avatar
No, as long as the pipe is the same size inside (and it should be).
Old Jun 29, 2013 | 07:58 AM
Roger350's Avatar
So which set-up is typically quieter, a resonated test pipe or a HFC?
Do resonated test pipes really knock out the drone like a stock resonator?
Thanks for the help.
Old Jun 29, 2013 | 08:27 AM
evolvedperf's Avatar
From my experience swapping between a Speed Circuit HFC and Test Pipe with ETS Quiet, there is no appreciable difference in performance or sound/volume. Its always loud and always fast so pick whatever makes you happy
Old Jun 29, 2013 | 01:04 PM
mshilto89's Avatar
Pretty much what Kendogg said, TP equals more power. Most of the guys running HFC are usually doing it because of restrictive emissions in their state(s).
Old Jun 29, 2013 | 05:30 PM
mp72's Avatar
If all you are doing is a cat back exhaust, then you don't need a test pipe. Get the HFC because the power you will make will be about the same. My HFC even passed CA tail pipe sniffer smog test.
You only need the test pipe when you are going for much bigger power with tons of mods.
03redtype-s
Dec 26, 2016 07:50 AM
03redtype-s
Dec 26, 2016 07:49 AM
380EVO
Evo X Dyno Results
Sep 14, 2016 07:01 AM
cla2000
Jul 25, 2016 04:04 AM
TxFAkuma
Jul 13, 2016 05:15 PM
