Sponsored by:
Sponsored by: CARiD
1st to 2nd
Old Jul 11, 2013 | 12:34 PM
jordan313's Avatar
1st to 2nd
Hey Guys, its been a day since I've got my 2014 GSR. I love it. Only problem I've noticed is that sometimes when I want to shift from 1st to 2nd, the shifter gets stuck for some reason and I have to wait like a second before it lets me into 2nd. Weird and it has happened twice now. I don't beat on the car or anything just normal transition to 2nd. Any ideas? I'm new to EVOs so i don't know much. I have 100 miles on it currently
Old Jul 11, 2013 | 02:29 PM
Dsimons's Avatar
My 2010 is the same way. I got it used with 31000 on it. Not sure if its suppose to be like that though.
Old Jul 11, 2013 | 02:41 PM
SD_Lurker's Avatar
The X has issues when it comes to shifting. Most people complain about notchy gears between 1-4. 95% of evos suffer from this..
Old Jul 11, 2013 | 02:47 PM
<3voX>'s Avatar
mine was from 2nd to 3rd when i first got it, with 10k miles now, it feels normal.
Old Jul 11, 2013 | 02:57 PM
Jake.barratt's Avatar
Same here with my 2012 with 8k miles. Part of owning a Mitsubishi lol.
Old Jul 11, 2013 | 04:07 PM
JustAnoterEvo's Avatar
Seems normal to me. Mine has been doing that for the past 2k+ Miles from 1st to 2nd then to 3rd. I now have about 3.5kmiles on it and it feels some what normal now. I don't get that notchyness all that often anymore. I don't beat on my car. The life of owning an Evo X I guess. lols
Old Jul 11, 2013 | 04:34 PM
Eazy's Avatar
Mine feels notchy, but I've never felt it get stuck and I've never had to pause for a second for it to engage
Old Jul 11, 2013 | 04:36 PM
ChipperEvo's Avatar
mine only feels notchy from 1 to 2 when the car is still cold. once it warms up, smooth as butter.
Old Jul 11, 2013 | 04:46 PM
ImEv0's Avatar
it may be your driving habits. my 08 gsr shift smoothly 1-2. when it's cold and the tranny isn't warmed up, the 2-3 grinds without the little trick however.
Old Jul 11, 2013 | 07:39 PM
GSRwithRotas's Avatar
Mine had a little stick between 1st and 2nd when i got mine and didn't worry about it to much. Then I did some work to the car and ended up putting the TWM short shifter with the full base and shifter bushings and it totally fixed the problem and it is fun with the short shifter. The full kit is about $500 bucks if you wanna spend the money but it definitely fixed the problem.
Old Jul 11, 2013 | 08:08 PM
4G63_EVO's Avatar
Maybe a driveline fluid change would help?
Old Jul 12, 2013 | 06:01 AM
Kracka's Avatar
This package will solve your problems, you won't find a better shifting X GSR transmission after you install this: http://www.maperformance.com/krackas...shi-evo-x.html
Old Jul 12, 2013 | 06:08 AM
Kendogg's Avatar
Whats the difference between getting 3 MT-85 or getting 1 MT-90 and 2 MTL?
Old Jul 12, 2013 | 06:19 AM
Kracka's Avatar
The cocktail is a closer match to the factory spec and is what I recommend in colder climates with a true winter. In the warmer climates, like Texas, the MT85 has a smoother feel.
Old Jul 12, 2013 | 07:49 AM
r34p3rex's Avatar
I found it feels better after a while.. let it break in a for a thousand or two miles first.
Like others have said, the "redline cocktail" tranny fluid supposedly makes a huge difference. Weighted shift knob may also help dampen out the notchiness.
Get base bushings for the shifter too! Reduces the play in the shift significantly
hearnoevo
Dec 11, 2014 09:42 AM
YoManStation
23
Dec 10, 2012 06:52 PM
Johnboy1065
24
Oct 10, 2011 08:01 PM
EricH
41
Oct 16, 2006 10:30 AM
