AMS STX300 vs. COBB OTS review
Just got back from a long night of datalogging and several sessions of runs in my stock '14 MR. Took time to let the car cool and be back to 'neutral' to avoid heat-soak and other power-stealers.
COBB ACN91 Stage 1 map- The car had an admittedly fun dr. jekyl and mr. hyde feel to it. The powerband definitely didnt feel linear and was almost addictive to be able to stomp on it and count 3..2...BOOST. I didn't have any knocksum or terribly fluctuating boost numbers either, so it would seem they've managed to fine-tune out that little snippit with this latest revision. However, while my peak boost numbers stayed within their claimed range (23.5 +/- 1.5) there was one nagging issue.. the SST didnt want to shift till the engine was bouncing off the rev limiter.. I would pull the shift paddle at 7k rpms, and almost no matter what, unless i took my foot off the accelerator, she would continue up to 7700 before she would shift.
AMS STX300 map- The car had a smooth and linear powerband all the way to redline. AMS's tweaking of the SST really shined and the car did what I told it to do. It wasnt as fun as the COBB tune acceleration wise, but the fact the car was overall more responsive with regards to throttle and shifting, makes it the winner for me. The AMS tune wakes the car up, but in a more reserved (see: safe) manner. Not that the car cant handle it, but I cant imagine bouncing off the limiter before it would decide to shift isnt a good thing..
Final thoughts for now: Ill probably stick to the AMS tune so I can have my jollies and not feel like im doing this every time I want the car to shift
Oh, one side note i should mention- with the COBB OTS tune, my car would actually accelerate HARD in 4th and 5th on the highway. Boost came on hard and fast, whereas with the AMS tune, she felt more lazy. Again, shifting issue aside, id probably prefer the COBB tune for the feeling of getting punched in the gut, but the AMS tune is much more linear and predictable for someone who wants to wring the cars neck.
Its not really fair to say one is safer than the other just based on perceived performance without wideband datalogging. You mentioned datalogging in your first post, do you have a wideband and if so was the cobb running significantly leaner?
the Cobb OTS shifting for the MR is a disaster and I think they just gave up on it. They made a bunch of promises in their forums, then didn't come through, then released a beta that screwed all our cars up, then released another one that fixed it, then the "final" release screwed it up again, they promised another fix, and instead, just deleted their entire forum
Have not tried the AMS tune, but my GSR is running stage 2 with no issues should be noted that I am using non Cobb parts and so my car my be dealing with the tune differently than it would if I was using Cobb hardware.
I got a 2015 MR with the cobb stage 1 + chff ACN91 map. Feels on point with what the OP mentioned. didn't feel linear, boost comes on hard and fast. I do get 1-2 knock count regularly and 3-4 knock occasionally. I've heard this COULD be just phantom knocks because SF streets are really REALLY bad. I'm running the newest tune they have out.
Only aftermarket parts I run are AMS UICP, cobb turbo inlet, and cosworth panel filter.
evo10fanatic33
10
Apr 13, 2016 09:50 PM
COBB Tuning
Cobb AccessPORT
95
Sep 24, 2015 07:35 PM
