Sponsored by:
Sponsored by: CARiD
suspicious oil leak
Old Nov 5, 2013 | 01:18 PM
marlonmck's Avatar
suspicious oil leak
Hey guys. I am seeing a suspicious oil leak at the right rear of my car just behind the right rear wheel. Please help if you know what's located there
Old Nov 5, 2013 | 01:25 PM
MR.Maxwell's Avatar
Raise the rear end of the car and look at your differential. If the damp spot appears to be in the area where the rear driver side axle connects to the differential, then it is likely a bad rear axle seal.
Old Nov 5, 2013 | 01:59 PM
ddawg1130's Avatar
I didn't know oil leaks could be suspicious... lol.
But as mentioned, go look for it. park it and see where it drips, then jack the car up and find the place it's dripping from, then take a pic and post it here.
Old Nov 5, 2013 | 02:00 PM
littlezrexer's Avatar
That would be the acd pump in the rear, take the clips off the liner and take a peak..
Old Nov 5, 2013 | 02:26 PM
Iowa999's Avatar
Agreed. Especially if the "oil" is red.
Old Nov 5, 2013 | 02:31 PM
meckert's Avatar
Old Nov 5, 2013 | 03:36 PM
marlonmck's Avatar
I will have to get that checked and I will also take a picture of it and let you guys see
Old Nov 5, 2013 | 04:11 PM
marlonmck's Avatar
What type of fluid goes in the acd uses. I see the container showing below minimum
Old Nov 5, 2013 | 05:25 PM
Iowa999's Avatar
SPIII A/T fluid
And cross your fingers that you didn't sink so low as to need bleeding.
Kylejj
May 31, 2016 06:13 PM
eh-jhey
Nov 12, 2013 08:32 AM
KJS
Jul 29, 2011 09:54 AM
JimGVT
13
Apr 21, 2011 07:38 PM
