Sponsored by:
Sponsored by: CARiD
whining at cold start-up
Old Nov 23, 2013 | 02:22 PM
Kracka's Avatar
Probably alternator whine. The cold causes more drain on your battery during start-up therefore the alternator has a higher draw on it.
Old Nov 23, 2013 | 02:38 PM
Omar Ramos's Avatar
Originally Posted by Iowa999
There's at least one reason that your buddy used to work on NASCAR vehicles, rather than currently heads a NASCAR team. A cold-air intake is under vacuum, not pressure.
They also don't produce the kind of noise in your video. But a cold power-steering pump will, for example.
If you refuse to sell the car, maybe get a louder stereo and wire it to come on before you start the engine. That might work.
first you dont know why he doesnt work there any more, second he is a co-worker and told me reguardless of the issue i still have a warranty and that they will find it, t isnt coming from my power steering pump btw its coming from my CAI and he said "its most likely a leak that you have of pressure and when its cold rubber pipes are hard creating and keeping the leak and once they heat up it expands and close, thus proving the only time i hear it is on the first start of the day, also he has more experience with cars and mostly imports than about 99% of these people on this site, so dont judge a book by its cover
Old Nov 23, 2013 | 02:42 PM
Kendogg's Avatar
Just curious,
If he has more experience with cars and mostly imports than about 99% of these people on this site, then why not go to him first?
Old Nov 23, 2013 | 03:29 PM
Iowa999's Avatar
Alright, so I teased a bit too hard. Sorry about that. But please keep in mind that the word "prove" isn't something to toss around casually and also that the title of a book is usually on the cover.
Oh, and please let go of the idea that the interior of a CAI is under pressure. That only happens when you run a certain throttle-body bought through a certain vendor and then add nitrous. tee hee
Old Nov 23, 2013 | 03:32 PM
Omar Ramos's Avatar
Originally Posted by Kendogg
Just curious,
i called him and he was busy putting a motor together, so until he had some time, which was a few hours, so i checked here to see if anyone had an idea what it was because obviously i didnt want to drive me car if it was going to break down on the way there
Old Nov 23, 2013 | 03:40 PM
Iowa999's Avatar
I think you need to watch and listen to your own video again. It's a mechanical whine and it's coming from the "front" of the engine. That's nowhere near the intake, but it's close to the power-steering pump, the alternator, and the oil-pump. Odds are, Kracka's guess is correct, simply because his would be one of the most educated guesses available. But you can at least test my guess (and, thereby, make me go away) in one minute: start the car and immediately steer side to side.
Old Nov 23, 2013 | 03:48 PM
Omar Ramos's Avatar
ill test your guess, steer side to side and what am i looking for exactly?
ok so i turned it on and as soon as i did i turned the wheel quickly in one direction and then to the other, the sound came on for a brief second and went away? this stating i have a problem with my pump? or what does this mean exactly?
Old Nov 23, 2013 | 04:24 PM
Iowa999's Avatar
Woo hoo. I win! Power steering pump whine. Absolutely nothing to worry about. Just verify the fluid and buy a louder radio.
Old Nov 23, 2013 | 04:35 PM
4EverWiKiD's Avatar
Veteran: Air Force
Way to boost his ego.
Old Nov 23, 2013 | 05:55 PM
Iowa999's Avatar
Yeppers. 9 out of 10 times that Kracka and I disagree, he's correct. I live for the 10th.
Old Nov 23, 2013 | 06:01 PM
701evo's Avatar
To bad i win . I guess ps pump first lol
Old Nov 23, 2013 | 07:40 PM
Omar Ramos's Avatar
so how do i fix this? replace the pump? the belt? add fluid? my fuild is near the min line
Old Nov 23, 2013 | 09:07 PM
701evo's Avatar
Just live with it. Fill her up and get on with your day. I recommend oem fluid
Old Nov 23, 2013 | 09:48 PM
Kendogg's Avatar
You shouldn't have said anything. Let him listen to that mechanic he knows that knows more about cars than 99% of the people on this forum. You should have let him take his intake apart.
Old Nov 25, 2013 | 05:18 PM
Omar Ramos's Avatar
btw the dealer looked at it and yeah it was the intake so the power steering pump was wrong lol
