Sponsored by:
Sponsored by: CARiD
Removing airbags
Old Feb 12, 2014 | 12:31 PM
sw2oboi's Avatar
Originally Posted by Johnr352
I'm not sure this is correct. Maybe the MUT tool, but not your standard scan tool.
Mut & Lexia
Originally Posted by Uscbryan
So does anybody have this tool in Southern Cal? Has anybody actually seen it work with airbags?
Does it actually turn the airbag warning off or just reset it?
Thanks
I paid a forum member on evox to change my ETACS. He is located in 626 area. He turned off my tpms, turn on auto door lock. He offered to turn off my air bag sensor for the seats in case I decided to go buckets in the future but I said no.
Old Feb 12, 2014 | 01:24 PM
Uscbryan's Avatar
Cool I'll look around.
Why do people turn the TPMS?
Old Feb 12, 2014 | 06:08 PM
Mr. Move's Avatar
You can use these in every airbag port
http://www.streettunedmotorsports.co...spl_xpsb_h.htm
Old Feb 12, 2014 | 06:35 PM
Uscbryan's Avatar
Those don't work for the passenger seat weight sensor. I made those myself for the seat airbag sensors.
Thanks
Old Feb 12, 2014 | 09:15 PM
Johnr352's Avatar
Thanks
Sheesh, even if it did, we'd need, what, 6?
Old Feb 12, 2014 | 09:46 PM
Uscbryan's Avatar
They are cheap to make. A few bucks could probable make you more than 6.
Old Feb 16, 2014 | 03:23 PM
Snakes709's Avatar
Originally Posted by Iowa999
I should have been clearer. What people use a Lexia-3 for (besides disabling TPMS and DRLs) is to turn the entire system off. You can't turn off bits and pieces of the system. It's all or none.
So just to confirm. This tool can and will shut off my airbag system and DRL's?
Reason why I ask is because I have HID's. I also have a relay harness installed but it stopped working (probably just the relay). However I would love to just shut DRL so I can clean up the wire clutter and drop the weight (my car is on a full out diet).
As well as I installed Corbeau seats and a 5point harness system. I removed my airbags so instead of wiring up a dozen resistors, would be easier to shut the system off.
Old Feb 16, 2014 | 04:19 PM
Iowa999's Avatar
Yes. The three most popular uses of a Lexia-3 is to disable TPMS, SRS (airbags), and DRLs.
Old Feb 16, 2014 | 05:23 PM
Snakes709's Avatar
is there any certain module or attachments I need or will any kit work?
spyderx
Feb 8, 2015 06:27 PM
Dr. EV0
Nov 25, 2014 01:10 PM
Eclipse10358
Lancer Troubleshooting
Aug 6, 2014 05:49 AM
mr2dsm
Aug 4, 2014 08:55 AM
texaspete108
04-06 Lancer Ralliart How To Requests / Questions / Tips
Apr 21, 2008 06:34 PM
