Sponsored by:
Sponsored by: CARiD
Just purchased my first Evo!
Old Apr 22, 2014 | 07:29 AM
AlexDRS94's Avatar
Hey guys I just purchased a 2010 WW Evo GSR. I just had a quick question for you guys. When I shift into 3rd it grinds and it has a little resistance. Clutch is not stock. From what I've been reading on here, people just recommend to put in some fresh tranny fluid. Is this something that I should be worried about?
Old Apr 22, 2014 | 07:45 AM
Keith6110's Avatar
I don't own an evo, but you should flush it anyway. It would give you a good idea of the condition of the transmission by what's in the old fluid coming out of it. No harm in putting in gear oil you know is fresh either.
Old Apr 22, 2014 | 08:05 AM
Alpha X's Avatar
https://www.evolutionm.net/forums/ev...on-thread.html
Old Apr 22, 2014 | 08:18 AM
kaj's Avatar
kaj
if you bought it used, changing out all fluids is really good insurance. i.e. i had a shop install a clutch for me.. come to find out they added Shockproof to the transmission. had i sold the car that way and not told the buyer, they (you) would be driving around with it that way. it's worth the piece of mind, trust me.
Old Apr 22, 2014 | 08:28 AM
AlexDRS94's Avatar
Good to know. I still haven't picked it up. I'll have the dealer change the fluids then. I was told by one of the salesman at the dealer that the guy that traded it in told him that he dynoed the car and it made 343 awhp. That's why I'm a little worried because it's going to be my DD
Old Apr 22, 2014 | 08:52 AM
galownia's Avatar
Welcome. Good advice above. I always change all fluids when I buy a used car. Cheap insurance.
Old Apr 22, 2014 | 08:56 AM
kaj's Avatar
kaj
do you know how it was tuned? if you can find out, then you can get yourself a Cobb AP/Tacktrix cable/etc to pull the tune off and have it checked. have you had a chance to check for aftermarket parts? to make much over 300-315whp i THINK you would need injectors (i'm not 100% sure with the Xs). if they are stock, you could always flash a stock ROM and start over. it's a bit scary buying a modded car without knowing the history but if it's coming from the dealership, that helps.
either way, i bet you can't wait to get your hands on it!
Old Apr 22, 2014 | 11:54 AM
AlexDRS94's Avatar
I don't know. I'll try to get as much info as I can from them. I bet everyone here has had that same feeling lol
Old Apr 22, 2014 | 12:14 PM
kaj's Avatar
kaj
psh.. i picked out my car and only had to wait until the end of the day and that drove me nuts LOL. it's my second one, but that didn't lessen the enthusiasm i had for it.
Old Apr 22, 2014 | 12:15 PM
galownia's Avatar
You don't need injectors for >300whp on the X. I have 327awhp on stock injectors on my X. Did require a tune and some flow bolt ons, however.
Old Apr 22, 2014 | 04:05 PM
AlexDRS94's Avatar
Checked it out and will be getting the redline cocktail from a local shop. Thanks a bunch!
I have to wait another day They still have to get the MD inspection done so I can go pick it up.
Old Apr 22, 2014 | 04:30 PM
kaj's Avatar
kaj
nice. with my IX, bolt-ons, and 91oct i was only getting 315ish.
take some Benadryl and sleep it off. LOL
Old Apr 23, 2014 | 05:35 AM
Kendogg's Avatar
Buying a used Evo will always run a level of risk. Even more risk if the car has been modded. But I currently have about that hp on my car. My point being that even if modded and putting down some hp, it can still be a solid car. I DD mine so most of my miles are while driving normally and usually out of boost. I also do regular fluid changes and preventive maintenance. I wouldn't be too worried about the increased hp unless you see obvious signs of issues or abuse.
That is assuming the prior tuner did not lock the tune.
Old Apr 23, 2014 | 07:23 AM
kaj's Avatar
kaj
that would suck.
Old Apr 24, 2014 | 07:18 AM
heath2029's Avatar
I would certainly flush it. Gratz on the new EVO! how do you like it?
#welcometothedarkside.
