Sponsored by:
Sponsored by: CARiD
Rally Armor
Old Jun 11, 2014 | 07:21 AM
mikebuff35's Avatar
Rally Armor
I am curious how well the rally armor mud flaps work. My friend has recently purchased them for his 2009 ralliart because he has pepper the back door and front of the back fender well from some gravel road driving. Do the mud flaps do a pretty good job of preventing this?
Old Jun 11, 2014 | 07:38 AM
slowsrt4:('s Avatar
the mud flaps do a pretty good job keeping most of the stuff off oof your rear bumper in my experience.
Old Jun 11, 2014 | 07:50 AM
mikebuff35's Avatar
Ok, because from what I have heard and read the paint chips fairly easily and before I purchase the car I am trying to find ways to help keep the paint pristine. I live in a more rural area so naturally, I am subjected to gravel roads, so chips are expected.
Old Jun 11, 2014 | 08:13 AM
Veronica's Avatar
Consider a 3M[tm] clear bra for the front
Budget replacing it every 4 to 5 years.
Old Jun 11, 2014 | 08:24 AM
mikebuff35's Avatar
I see theres pre cut sized ones for cars as well as spray. I assume the pre cut would be better for removal and replacement?
Old Jun 11, 2014 | 10:28 AM
Jerm6908's Avatar
I like my red ones they def get black an muddy...I still have stones kick up though it may be because i'm on a stock height an on others i see them closer down to the road almost touching......Which i think would do better?
Old Jun 11, 2014 | 12:41 PM
mikebuff35's Avatar
Probably better lower but I figure I would keep the height as is because I enjoy ground clearance especially because what the Evo is designed for. My car now is an inch or two lower than an Evo and I scrape on everything...
Old Jun 11, 2014 | 01:01 PM
Jerm6908's Avatar
I live in PA also in a small valley an the roads are garbage I'm keeping my stock height also an just getting 19 inch rims or 20's to fill that wheel gap
Old Jun 11, 2014 | 01:52 PM
mikebuff35's Avatar
Ya thats a good idea Ill probably do the same.
Old Jun 11, 2014 | 08:54 PM
Jdjones24's Avatar
Mud flaps do their job as protecting your paint but I cannot stand how they look on the car. Takes away the fine lines of the vehicle. I think mud flaps only look good on a minor lowered eve with wide wheels. Just my opinion no haterade needed.
Old Jun 12, 2014 | 01:05 AM
mrFabro's Avatar
The RA mud flaps lasted for years on my old WRX and was a great investment to protect the paint and I had no major issues with them. In fact I liked them so much that one of my first mods was to buy another set for my new EVO. Plus they are easy to install, and it's a good quality product.
[IMG][/IMG]
Old Jun 12, 2014 | 04:34 AM
tkromer's Avatar
You will get a smaller tire to accomodate the larger wheel and end up with exactly the same gap. Don't do that.
Old Jun 12, 2014 | 05:53 AM
Jerm6908's Avatar
Ohh aight good looks....But i'm still gonna get 19s an i know i wouldn't be the only one with 19's.
Old Jun 12, 2014 | 07:03 AM
Cosmic Starship's Avatar
The evo's sidewall on stock gsr rims is already really tiny. You can always just buy larger sidewalls to compensate and put up with the adjusted gear ratio. If I ever buy aftermarket rims, I use it as an opportunity to adjust the gearing if need be. On the evo, a little larger circumference could help with that highway cruising if you manage to get the car out of boost (if you care about things like that). More MPG and less drone.
Old Jun 12, 2014 | 07:16 AM
Jerm6908's Avatar
[IMG][/IMG]
Was this MR bought from a ford dealer is that why i see a ford license plate bracket lol.
