Sponsored by:
Sponsored by: CARiD
HVAC help - blower working but no hot or cold air
Old Jun 12, 2014 | 10:32 PM
plip630's Avatar
hi!
need help in diagnosing problem on my HVAC system in my evo x.
the blower is working but no hot or cold air. its same temperature of air even i put in hot or cold.
the car was stored in the garage during winter and just last week.
the only thing i did during it was stored is to put an aftermarket double din, but i put back the stock radio because there is a problem with the double din that i install.
after i put back the stock stereo i notice only notice it last week when i used my car the AM station are not working but FM stations are ok.
only trouble i encounter during installation of the aftermarket stereo was blown fuse and replace it.
no more warranty on the car, hoping to get help before bringing it to the shop.
thanks
Old Jun 16, 2014 | 01:13 PM
ikt's Avatar
ikt
Originally Posted by plip630
hi!
thanks
does the button for AC and Recirculate light up when pressed?
The HVAC unit is a digital piece, and runs off a harness. If the lights light up as they should, that part is probably okay. I'm leaning towards a loose harness, since you changed the stereo and this is all one unit.
The other places to check, if the HVAC controller appears ok:
the AC condenser, behind intercooler. Heater core is in the dashboard.
My honest guess is that you shorted something out when replacing the stereo. The fuse blew because a power wire hit something it shouldn't have. Also, the AM quit working? Check antenna connection I guess. But odds are, you blew another fuse and don't realize it, or, fried the HVAC control unit. I recommend eBay for replacement. You can use either an Evo one, or an Outlander one with digital control.
Good luck!
Old Jun 17, 2014 | 08:54 AM
Veronica's Avatar
(there is no 'AM antenna' connection - it is integral to the radio)
Old Jun 19, 2014 | 07:32 AM
khmerguyx's Avatar
Not sure if you fixed it yet but were you at any point doing something in the engine
Old Jun 23, 2014 | 04:22 PM
plip630's Avatar
Good luck!
Yea there is a light on the controller.
How do i test the air condenser? Or the heater core?
Ill probably check behind the dash for loose harness.
Thanks
Old Jun 23, 2014 | 04:25 PM
plip630's Avatar
Its not yet fix. No time to bring to a mechanic.
Im not doing anything on the engine.
Old Jun 24, 2014 | 12:58 AM
MaxR's Avatar
water pump probably dead
Old Jun 24, 2014 | 05:37 AM
Veronica's Avatar
^no. Only if OP complained of overheating engine.
Not switching from heat to cool is either the control panel or the flapper door actuator on the HVAC box.
Do you have another Lancer you could quick swap out the HVAC panel with? Takes maybe 20 minutes...
rayman0690
Jan 4, 2026 07:20 PM
LeXcite
Jan 17, 2022 08:05 PM
josephatgts
Lancer Troubleshooting
Sep 18, 2016 02:23 PM
kd5byb
Sep 7, 2013 05:44 AM
kyoo
Oct 25, 2011 07:23 AM
