Sponsored by:
Sponsored by: CARiD
Strong exhaust smell? - high flow cat
Old Dec 14, 2014 | 09:53 PM
rydogg008's Avatar
Originally Posted by Jdjones24
Never had this issue with my ETS High Flow Cat. Installed the HFC on a Thursday and drove to Orange County the next day for a Baka tune!!! Been running on the tune for the last 8 months at 15,000 miles.
Cool, thanks for your reply. I'm pretty sure it's some kind of exhaust leak. I'm gonna put it on the lift this week and see what I find.
Old Dec 15, 2014 | 10:15 AM
FALCO's Avatar
monolithic catalysts have a cells/square inch rating. I assume a high flow cat would have less cells per square inch which means less surface area assuming same depth in direction of flow. Fewer cells per square inch also results in lower destruction efficiency. Other factors being equal, fewer cells per square inch results in less pressure drop across the converter, resulting in a less restrictive and less effective converter. That converter probably works well at idle.
Old Dec 16, 2014 | 06:22 PM
Charlienofun's Avatar
Attempting to post pics... Anyone know the right way to use these clamps from buschur?
Old Jan 11, 2015 | 02:54 PM
evolvedperf's Avatar
Just a thought here... you might want to check in the trunk area, drivers side behind where the Rockford Fosgate sub sits, behind the carpet. There is a square flapper thing that relieves pressure when you close the trunk/doors or something. If that is missing or has fallen out, and you drive with the windows down or cracked it will suck tons of exhaust smell into the car.
Took me forever to find that issue in my car hope it helps
Old Jan 13, 2015 | 09:10 AM
rydogg008's Avatar
Thanks...I'll check that.
Old Jan 16, 2015 | 06:01 AM
Thomar's Avatar
Looks right. Take the rattler to it. And by rattler I mean impact gun.
Old Jan 18, 2015 | 08:53 AM
MR.SScott's Avatar
Veteran: Army
Originally Posted by rydogg008
Ya, I've been to FFtech and have had a pro tune completed.
Well there's your problem right there...
Old Jan 19, 2015 | 12:31 PM
Hotevo3's Avatar
Grab a flashlight and start looking under the car, you should be able to see black soot around the leaking area. Also see about new gaskets or adding exhaust sealant paste in between parts. I have a test pipe and I only smell exhaust when sitting still.
Old Jan 20, 2015 | 10:11 AM
rydogg008's Avatar
Thanks! Yep, i definitely found some leaks so I had all the joints welded. Much better now.
Old Jan 21, 2015 | 12:00 PM
honestabe's Avatar
Spot welds? What was the reason for the leaks?
Old Jan 21, 2015 | 01:38 PM
STM Tuned's Avatar
Sounds like an exhaust leak, possibly needs a tune
-Ethan
Old Jan 22, 2015 | 12:11 PM
rydogg008's Avatar
Ya so this has been basically solved through a combination of things:
-I could't get the slip-on clamps that I used from the catback kit tight enough, and they were leaking slightly. The bolts stripped when I torqued them...so welded the junctions
-The seal between the cat and the catback wasn't aligned and tight enough. This was an easy fix
-Finally, I moved back to the factory cat - which sucks but strong exhaust smell is worse.
I do think there is a possibility that my tune is too rich/could be more lean. I have a wideband kit that I'm going to install soon and will start logging to find out for sure.
I appreciate all the posts and the help!
Finally, wanted to give a shout-out to ETS - their customer service is top-notch and they were super helpful throughout. I would highly recommend them as I know they stand behind their products!
-Ethan
Old Feb 10, 2015 | 01:44 PM
Fede's Avatar
Did the same. I'll give a shot to an HFC, but with my old TP I can't breathe.
Silver09RA
26
Jul 24, 2014 10:05 PM
phantomwilson
Jan 28, 2011 11:34 AM
Evo348
56
Sep 26, 2005 07:43 PM
surfocean
Dec 26, 2004 11:32 AM
EvolvedfromaWRX
Mar 27, 2004 05:17 PM
