Sponsored by:
Sponsored by: CARiD
Buying my first Evo
Old Jan 6, 2015 | 12:25 PM
Ryanlal's Avatar
Buying my first Evo
Hey guys Im looking for some help about buying a used 2008 GSR. This is my first evo and im not sure what I should look for and what question I should ask when Im at the dealership. I know my way around a car so the basic I can check but wasn't sure if there would be something specific i should look for or ask when I go see the car this weekend.
Any help is much appreciated. Thanks in advance.
Old Jan 6, 2015 | 08:21 PM
Napalm_Enema's Avatar
Mileage - what is it?
If close to 100k demand timing chain replacement. Any maintenance records you can secure are good. Take pictures of the engine bay on here so people can tell you what mods it might have if any. Check under the car to see how badly it's corroded.
Few things off the top of my head, others will chime in.
Mileage is key, let us know that and we can advise further.
Old Jan 7, 2015 | 04:41 AM
Ryanlal's Avatar
109xxx the dealer does not have any pics of the engine bay and I won't be able to go see it until this Saturday. I know its been modified because there is an exhaust (not sure what but i will find out and there is a competition clutch sticker in the truck on the back of the rear seat). Im glad they have timing chains, I've heard they are much better than belts...is that true with evo's?
I'll get the pics and post back thanks again.
Old Jan 7, 2015 | 06:30 AM
Yes and no. Prior to 2011 the timing chain is prone to stretching as I understand it. Hopefully some people with 08 EVO's can chime in with their input. I'd insist on a timing chain install with that many miles or walk away imo. (minimum)
Old Jan 7, 2015 | 07:29 AM
Ryanlal's Avatar
Thats good advice...I definitely don't want the headache. The engine bay looks clean with little mods...oil catch pan aftermarket intake and intercooler piping...Am i missing anything?
Old Jan 7, 2015 | 08:07 AM
I'm no EVO expert. I'd post this over at:
http://www.boostedforum.com/
and also
http://evoxforums.com
This way more people will respond and give you feedback before you spend any money.
Good luck!
Old Jan 7, 2015 | 08:09 AM
Ryanlal's Avatar
and also
Good luck!
will do thanks.
What about reliability...do you guys think its generally a good car?
Old Jan 7, 2015 | 07:35 PM
LB_Reddy's Avatar
08 mr .still stock 26k no problem
Old Jan 7, 2015 | 10:33 PM
Fawkz's Avatar
BOV is aftermarket to, did you check the boost controller ?
Old Jan 8, 2015 | 12:36 AM
Mevo3's Avatar
I would try to find a evo with lower miles. The bov to atmosphere is not a good idea. Also, side note, the oil "catch can" you have to be carful. Maybe the car has too much blow by. I've seen people add them on worn out motors for that reason. Just saying. Good luck
Old Jan 8, 2015 | 04:24 AM
Ryanlal's Avatar
Im going to check the car out this weekend. What should I check for?
Old Jan 8, 2015 | 08:09 AM
Fawkz's Avatar
just check the boost control solenoid and see if its stock or aftermarket, if its aftermarket ask if they had the car tuned, or if they will let you, see if its tuned yourself. Aftermarket EBCS can cause overboosting without a tune.
Also the timing chain and ACD pump are common to go out on these. The ACD pump especially in cold places ( I see snow )
Old Jan 8, 2015 | 08:27 AM
Ev0ikon's Avatar
When buying used cars I always asked for all factory repair/recalls done and then a proper leak down test.
Old Jan 8, 2015 | 06:16 PM
.M.'s Avatar
.M.
If you're not sure what to look for, take someone that does. Even if you have to pay them. Better safe than sorry
Old Jan 8, 2015 | 09:04 PM
Mevo3's Avatar
Pay to have a PPI. Make sure they give you all the specs. Including rotor measurements. I forgot to measure my rotors and they where under spec, rotors are not cheap!
