Sponsored by:
Sponsored by: CARiD
Ticking noise, haven't seen or heard of this before.
Old Mar 16, 2015 | 06:48 PM
Buguy's Avatar
Hey guys bought my car in 2011, after storing it this winter fired it up for the first time and immediately after the car warmed up I noticed this very strange tick whenever I give it any type of gas. Very loud and noticeable tick with windows rolled up, very frustrating as it gets louder and ticks quicker as the revs get higher.
Video of sound:
http://vid91.photobucket.com/albums/...6/IMG_0761.mp4
Old Mar 18, 2015 | 04:27 PM
Buguy's Avatar
bump
Old Mar 18, 2015 | 05:03 PM
kaj's Avatar
kaj
if the car sat a while, maybe one or more of your lifters got stuck. is it coming from under the valve cover? i can't view vids from work.
it's not the injectors, correct?
Old Mar 18, 2015 | 05:35 PM
meckert's Avatar
How is your oil pressure---do you have a gauge?
Old Mar 18, 2015 | 08:37 PM
Buguy's Avatar
I don't have an oil pressure guage and car seemed to do this before i put it away too but not as noticeable .
Old Mar 18, 2015 | 09:50 PM
yifuqiao's Avatar
I think it is probably oil pump noise.
Start from getting your oil changed and see if it changes..
I think yours is a bit extreme.
When did you change your oil last time?
I believe even if you don't drive, you are still supposed to change oil frequently..
3months or 3k for me.
Old Mar 19, 2015 | 08:59 AM
LB_Reddy's Avatar
Let it run for good of 30 min to let oil circulated.When oil settle for awhile liquid become thicken.Changed the motor oil.
Old Mar 19, 2015 | 09:02 AM
kaj's Avatar
kaj
common oil change frequency is 6mos or the recommended mileage, whichever comes first. letting your car sit a few months isn't going to hurt it.
Old Mar 19, 2015 | 10:59 AM
meckert's Avatar
Ok, so run some motor flush in it---READ the directions---change the oil. If you cant find any, try running some trans fluid in with the oil at IDLE ONLY for maybe 10min, the noise should fade away , this will free up any sludge and unstick a lifter if its stuck. Do NOT drive with any of these in your oil---change the oil. You should be done then.
Old Mar 19, 2015 | 12:50 PM
Sephiron's Avatar
^ is that actually safe? I've heard of some people doing this but I feel like its nothing a more common treatment of something like Seafoam in the oil for a few miles can't also fix.
Old Mar 19, 2015 | 12:53 PM
hoobastnk90's Avatar
i would think sometimes broken up gunk is more dangerous than gunk that has been stuck on a long time. i would just change the oil first and go from there.
Old Mar 19, 2015 | 02:13 PM
kaj's Avatar
kaj
Interesting if the trans fluid thing works. That would be a good thing to know.
Old Mar 20, 2015 | 06:37 AM
Thomar's Avatar
I dont hear a tick but I do hear the oil pump. Normal for Evo X's.
Old Mar 20, 2015 | 08:19 AM
Veronica's Avatar
^yes, this is safe.
The Seafoam in the oil is the same procedure. Do not drive with it in. Just idle and drain The engine won't 'blow up' but you accelerate wear with thin oil not reaching pressures and 'sticking' to things like cylinder walls...
Old Mar 22, 2015 | 06:06 PM
meckert's Avatar
Originally Posted by Veronica
^yes, this is safe.
Good Lord---Thank you. You all need to remember the trans fluid is actually a lube for the trans as well---a lube none the less. Its high detergent and there fore breaks down a lot of sludge--. This is an old school way of freeing up lifters-- and yep I am old school. Under non circumstances I wouldnt recommend something I "heard" or didn't have first hand knowledge of it working. Hell I gave specific instructions.
