Sponsored by:
Sponsored by: CARiD
having problems removing screw plugs
Old May 3, 2015 | 11:31 AM
TxFAkuma's Avatar
How do u remove those 2 screw plugs for the stock filter? It just keeps rotating but it does not un screw! Any simple suggestions?
Old May 3, 2015 | 01:18 PM
meckert's Avatar
Sure, get a small flat blade screw driver and slide it under the collar and apply a little upward pressure---that will allow the threads to catch and unscrew---then you can pull it out. Get on ebay and buy a bag of screw thingies--what ever they are called, and just pop them all the way out next time and replace them as needed---much simpler. good luck.
Old May 3, 2015 | 04:37 PM
.M.'s Avatar
.M.
Try holding the outer part with your fingers, or like stated above use a flat head. Either pry it up, or try holding it down. Don't use a lot of force on the screw itself, or you'll just keep pushing it back down and it'll keep spinning.
Dbzguy
Dec 31, 2014 05:37 AM
lalu
May 2, 2012 06:33 PM
HimynameisWillzyx
Aug 19, 2010 04:49 PM
Defcon5Es
Aug 31, 2009 04:41 PM
MrBonus
May 31, 2008 06:52 AM
