Sponsored by:
Sponsored by: CARiD
Can i put a 7" DVD player inside a 6.1" Dash?
Old Jul 24, 2015 | 01:32 PM
TxFAkuma's Avatar
Hey guys, will a 7" DVD touchscreen unit fit into my GSR without any dash kit or modification? I was told that it would fit and then i was told it would not. I'm trying to get a Bluetooth DVD player in there. I know i will need to find a adapter for the steering wheel controls but thats okay because i will. My only concern now is.. Am i forced to buy a 6.1" unit (OEM Unit) or can i fit a 7" screen?
I was going to shop at crutchfield.com and when i select the "2014 Lancer" it says it WOULD fit...
Old Jul 26, 2015 | 09:11 PM
JDZNate's Avatar
Veteran: Air Force
Can you fit a square peg into a round hole?
Old Jul 27, 2015 | 08:21 AM
TxFAkuma's Avatar
That depends on how big the hole is.. but possibly, yes.
Old Jul 27, 2015 | 09:34 AM
Veronica's Avatar
Pioneer App Radio 2 (7" screen fits fine)
Key is that the radio is double DIN.
Old Jul 27, 2015 | 01:45 PM
TxFAkuma's Avatar
Perfect. Now i know a 7" screen fits. Thank You.
Old Aug 7, 2015 | 07:54 PM
TxFAkuma's Avatar
Does anyone know if I need a new dash kit for the 7" double din ?? Or will the OEM dash fit it?
Old Aug 8, 2015 | 02:43 AM
AlexDRS94's Avatar
Like Veronica said above, as long as it's double din it should fit. Since you have the RF system you will have to buy the metra Mito-03 for anything to work.
Old Aug 8, 2015 | 03:15 AM
TxFAkuma's Avatar
Could you post a direct link to the metra mito-03 system here? I was curious if you think the metra system would work better than the Pac-Audio SWI-RC ? http://www.pac-audio.com/productDeta...&CategoryID=29
Old Aug 8, 2015 | 03:21 AM
AlexDRS94's Avatar
I don't know what you're going to install but it looks like the pac has a lot of exceptions to what you can and can't install. Here's the link for the metra from newegg. It's a lot cheaper here
http://m.newegg.com/Product?itemNumb...eyword=Mito-03
Old Aug 9, 2015 | 06:08 AM
TxFAkuma's Avatar
So basically i need to get the metra mito-03 and the Axxess ASWC-1 Steering Wheel Control Adapter for my steering wheel controls to work? I don't think i understand this fully yet then... Can't i just buy the 7" in dash and get the steering wheels controls functionality to work with a PAC SWI-RC? Is it necessary for me to get the Metra Mito-03 to maintaining the use of the factory amplifier even though i do not have the Rockford sound system?
I actually installed a aftermarket sub and amp already. I thought only the Rockford system came with a amplifier under the driver seat therefor they would be the only ones needing the Metra Mito-03?? ... right?
Old Aug 9, 2015 | 09:35 AM
AlexDRS94's Avatar
Sorry I assumed you had the RF system. You don't need the mito, just the steering wheel control adapter. Nothing else. Just make sure you get one for your MY. The wiring is different on the older Xs
Old Aug 9, 2015 | 11:46 AM
TxFAkuma's Avatar
Thanks for your help
StreetThisEvo
Sep 5, 2009 09:04 AM
Xearo
11
May 4, 2009 05:01 PM
NJ_evoIXgsr
Jul 15, 2008 09:18 AM
LancerChicka84
Sep 2, 2006 02:39 PM
