Sponsored by:
Sponsored by: CARiD
Boost
Old Aug 3, 2015 | 05:57 AM
Mikeodeth's Avatar
Boost
Hi guys i need help. I have a cobb apv3. During idle the boost reads negative 8 to 9psi. But when i drive at at 5000 rpm it will only go to 17psi. Im using stage 1.
Pls advise
Old Aug 3, 2015 | 06:35 AM
hoobastnk90's Avatar
sounds fine.
Old Aug 3, 2015 | 07:27 AM
JagMix's Avatar
negative is the amount of vacuum...boost starts to build at 0.
Old Aug 4, 2015 | 04:50 AM
Mikeodeth's Avatar
Thanks guys
Old Aug 5, 2015 | 07:25 AM
jayt27's Avatar
I thought boost peak was suppose to hit 23-24psi on stage 1. At least mine did when I had an AP.
Old Aug 5, 2015 | 11:29 AM
Viegasjuice's Avatar
That vacuum doesnt seem right at all(assuming your on stock cams). I sit at -20
Old Aug 5, 2015 | 11:37 AM
AlexDRS94's Avatar
I'm using the AP3 and I'm reading -12 and hit anywhere from 24-28 psi on the Stage 1 map. I believe I have a leak somewhere
Old Aug 10, 2015 | 05:13 PM
akride907's Avatar
[/INDENT]
Probably just a units issue. My AEM boost gauge has ticks for both inches of Mercury and psi. The -8 in HG is relative to the vacuum, which when converted to the relative atmospheric pressure in psi is around -18/-19.
bwanner
Aug 31, 2012 05:38 PM
wingnut
Jan 20, 2005 11:11 AM
blue beast
Mar 29, 2004 02:52 PM
