Sponsored by:
Sponsored by: CARiD
Question about.....glue?
Old Aug 24, 2015 | 05:28 AM
chronozon's Avatar
Washed the car over the weekend and noticed this, the glue came loose I guess on the rubber trim right in front of the rear tire above the side skirt, never happened to me on any car I've had before, any suggestions on what type of glue to use to put this back in?
Old Aug 24, 2015 | 06:06 AM
splattj's Avatar
That strip might be held in with a friction fit. Is there glue residue on it?
If so, 3M weather strip adhesive is stickier than gorilla snot and designed for what you need. I like it because it's black like the rubber unlike some of the glues out there.
Amazon.com: 3M 08008 Black Super Weatherstrip Adhesive Tube - 5 oz.: Automotive Amazon.com: 3M 08008 Black Super Weatherstrip Adhesive Tube - 5 oz.: Automotive
Old Aug 24, 2015 | 06:15 AM
nvmaddog's Avatar
You have to tuck those pieces back in. I have the exact same issue every now and then, there is no glue from the factory on the ends of those pieces.
Old Aug 24, 2015 | 06:50 AM
chronozon's Avatar
I checked when I first saw it Saturday and it does have some residue on there, I'll check out the link, thanks.
I've tried to tuck it back in and just keep coming loose every time I drive, the same trim on the other side is solid. It's rubber touching metal on top and plastic on bottom, I'm going to try to glue it back down.
Old Aug 24, 2015 | 07:09 AM
Napalm_Enema's Avatar
What about taking the end with a pair of pliars, then pulling it past the crack (stretching it), then working it back into that crease completely? Doesn't seem like it would jump back out unless there is a bigger hole back there that allows the air to push it out?
Old Aug 24, 2015 | 07:18 AM
chronozon's Avatar
Thanks, I'm going to try that and also with a wedge used for window tinting to try to push it back in first before gluing it down.
army685
Mar 6, 2005 09:28 PM
blue8sc
23
Feb 19, 2005 03:19 PM
Casper
10
Jun 3, 2004 09:16 PM
WorkinProject
Apr 11, 2004 06:32 AM
Chicago Lancer
Jul 22, 2003 01:44 PM
