Sponsored by:
Sponsored by: CARiD
AFR everywhere
Old Nov 18, 2015 | 07:03 PM
irwintan27's Avatar
AFR everywhere
Hey guys, I've been having problems with my 2011 Evo X. So my AFR keeps jumping between 11 and 18. When it goes to 18, I can feel a huge loss in power like suddenly I'm pulling a trailer with another car in it. It'll be like that for like a second or two until the afr goes to the other side. Also, before I can use my AC and it wont affect my idle at all, then recently when I turn on the AC the tach will keep jumping back and forth between 1k and 500 and sometimes will stall the engine. Some days it'll do that and some days I can turn on the AC and its fine.
Mods are:
GSC S2 Cams and springs
FIC 1100
AEM 340 Fuel Pump
Synapse BOV
K&N hi flow intake
TopSpeed Test Pipe + Catback
3 port EBCS
Any help is appreciated!
Old Nov 18, 2015 | 07:13 PM
JakeSoberman's Avatar
Mods are:
FIC 1100
AEM 340 Fuel Pump
Synapse BOV
K&N hi flow intake
3 port EBCS
It may be your fuel pump relay when they die the car runs super lean. You should replace yours immediately and stop driving the car.
Old Nov 18, 2015 | 07:19 PM
irwintan27's Avatar
You know what? You might be right, I still got the stock one if I remember correctly (Just bought this car recently). Ill go check and swap it for now and see if it improves.
Old Nov 18, 2015 | 10:18 PM
irwintan27's Avatar
I swap the relay a few times with a different relay and the problem still persists.
Old Nov 19, 2015 | 04:51 AM
AngryEvo's Avatar
AC affects my idle and I'm stock so that's probably not the issue. I would think its the tune or fuel pressure related .
Old Nov 19, 2015 | 05:59 AM
Napalm_Enema's Avatar
Who tuned your car, when was it tuned? Did it ever run right as it sits? These are the answers people need to better assist you.
Old Nov 19, 2015 | 09:26 AM
SVPxTuRbO's Avatar
You check your fpr vacuum to make sure it didnt pop off?
xPRimNT
157
Dec 26, 2018 08:09 AM
bluedemon199
16
Sep 22, 2014 08:27 AM
Appauldd
Mar 24, 2009 10:29 PM
PlanoEvo
Oct 3, 2007 08:30 PM
nj1266
Mar 5, 2007 07:52 PM
