Sponsored by:
Sponsored by: CARiD
How to keep this from happening? (power steering line crack)
Old Nov 22, 2015 | 03:56 PM
dragon831's Avatar
Earlier in the year I had a small leak coming from one of the hardlines attached to the steering rack so I bought a used steering rack and took off the needed line (I cant find a real new line without ordering an entire steering rack assembly). Once I took off the old line, I could see a small hairline crack. This time however, the cracks seems to be a little more serious
This is my 2nd line to crack like this right before the flared end of the tubing. I had bent it away from the sway bar to make sure it wasnt hitting it but it still cracked within 200 miles. Any suggestions?
Old Nov 22, 2015 | 07:38 PM
gtr's Avatar
gtr
I would suggest ordering a new one just because rubber ages. Sometime the manufacture make changes and improvement unannounced because of design flaw.
Old Nov 22, 2015 | 07:55 PM
dragon831's Avatar
EH? There's no rubber there, just some metal tubing that's cracked right before the flared section. I have another one on the way, but it's going to be the same exact thing :-(
Old Nov 24, 2015 | 01:45 PM
hoobastnk90's Avatar
Man I remember your thread a long time ago about this. So you couldn't track one down from the dealer without buying the whole thing huh?
Old Nov 24, 2015 | 08:58 PM
bobssecrtsn's Avatar
I dont think thats fixable.. order a new one.
Old Nov 27, 2015 | 04:09 PM
dragon831's Avatar
Tried EVERYWHERE! around $1200 for the steering assembly and that's the only way to get a new line. I found a hydraulic shop that said they should be able to replicate it for me, but the thing is I need to find out what's causing these lines to crack in the first place. I made sure there was at least 1/4" to 1/2" clearance between the power steering line and the swaybar and the engine mount. Cant seem to figure out what's causing the problem
Old Dec 1, 2015 | 07:13 AM
Veronica's Avatar
Generally speaking, a split like that is caused by lateral stress and/or sub-standard cast metal.
I doubt it is over-pressure causing the line to fail.
Is the line under stress when installed? Does it take a lot of side-ways push or pull to get the fitting on?
Could you splice-in some medium pressure braided hose?
(hard to tell from the picture)
true4nae
16
Nov 10, 2014 09:50 AM
xXANCHORMONXx
Aug 7, 2014 08:23 AM
agent712
Dec 8, 2007 11:10 AM
