Sponsored by:
Sponsored by: CARiD
Full fluid change?
Old Mar 15, 2016 | 02:46 PM
RATEDX's Avatar
Question Full fluid change?
Hey guys, coming up on 22k on my gsr, its going on 3 years old looking to change all the fluids, what needs to be changed? and what fluids do you recommend? Thanks
Old Mar 15, 2016 | 05:42 PM
DeweyD's Avatar
You will probably want to change
5 Speed Transmission Fluid
Transfer Case oil
Rear Diff LSD gear oil
Rear Diff ATF fluid (this is what the AYC clutch plates sit in)
The rear diff has two fill plugs, one for each fluid type. A lot of people get confused over this. The ATF fluid in the rear diff is separate from the pressurized ATF fluid that runs through the pump/solenoids in the AYC/ACD setup. The pump/solenoid fluid is what is fed by the little bottle in your trunk. You do not need to change this.
I recommend stock fluid from Mitsu for everything, with the exception of the 5 speed tranny fluid if that floats your boat. A lot of people like Redline 85 weight fluid or a similar blend of fluid weights.
ecl27
12
Mar 3, 2014 10:28 PM
Dbar4G63IX
Jun 1, 2010 07:03 PM
Pure Playaer
74
Nov 25, 2009 08:17 AM
afmafia
Nov 24, 2009 07:32 AM
