Sponsored by:
Sponsored by: CARiD
Need assistance. Confused with Tires.
Old Apr 21, 2016 | 02:39 PM
Mahawka's Avatar
93, standard load.
The load index and rating has nothing to do with sidewall stiffness. Its how much weight the tire can hold, and at what air pressure it holds that weight. The OEM tires are 93 standard load. No reason to go higher.
The reason is that it's $70 dollars cheaper.....
Will it be a problem running the 97?
Old Apr 21, 2016 | 02:42 PM
LetsGetThisDone's Avatar
No, it won't hurt anything. Just go with whichever is cheaper. As long as you're not buying a run flat.
DrivelineSales
Aug 1, 2008 11:52 AM
