Sponsored by:
Sponsored by: CARiD
2013 Evo X GSR - 7670 T4 Kit Missing Target Boost
Old Jun 6, 2016 | 11:22 AM
ddlopresti's Avatar
So i'm missing my target boost of 29 by about 4 or so. My AFRs seem about right and I was thinking it could be a small Exhaust side leak, what bolts should i check out to rule that out or I guess it could be a gasket as well that tightening a bolt wouldn't cure?
Old Jun 6, 2016 | 12:06 PM
sujinX's Avatar
have u done a boost leak test?
are you tuned for the 29 psi?
boost leak first, then check the exhaust side stuff.
Old Jun 6, 2016 | 12:16 PM
shekaar's Avatar
What are you basing the numbers from? What are you tuned on?
Old Jun 7, 2016 | 09:16 AM
ddlopresti's Avatar
Yes, I am tuned for 29 on E85. I'm running a v3 rom with the zeitronix flex fuel kit. The numbers are based from my AEM Wideband and boost gauge. I haven't done a boost leak test yet, that is on the agenda for this week but based on my previous experience with boost leaks that seems to correspond with a rich AFR and my AFRs are not rich at all.
Old Jun 7, 2016 | 09:39 AM
shekaar's Avatar
The boost gauge will read somewhat different than what you're actually tuned for usually. Is this a new issue all of a sudden?
Old Jun 7, 2016 | 11:01 AM
ddlopresti's Avatar
yes, it was running 29 psi according to evo scan and my boost gauge and now it is running 25 or so. The drop in power is very noticeable, it started over the past weekend. Ambient temps were the same and running twin external wastegates the setup has been very reliable and precise re hitting target boost in different temps.
Old Jun 21, 2016 | 02:57 PM
ddlopresti's Avatar
so the issue was figured out, the crush washer on my external wastegates somehow got deformed, maybe from the heat? and that was keeping the turbo from hitting the target boost. Anyone else heard of this happening?
Old Jun 21, 2016 | 03:07 PM
sujinX's Avatar
assuming ur talking about the washers that go on either side of the air nip, sure, anything that is suppose to hold air and leaks will cause this problem.
crush washers are only suppose to be a one time use thing.
Old Jun 22, 2016 | 07:42 AM
ddlopresti's Avatar
yep, talking about those and yes I wasn't reusing them, i only removed it when i noticed i was missing target boost and then put back in new ones.
ddlopresti
Evo X Dyno Results
26
Dec 26, 2017 11:27 AM
ddlopresti
May 14, 2015 07:16 AM
JEDMESTON
Evo X Dyno Results
10
Nov 14, 2013 06:48 PM
bobby.is.rad
Mar 21, 2012 12:21 PM
rartist
23
Jun 23, 2005 12:48 PM
