Sponsored by:
Sponsored by: CARiD
Messed up ABS & AWD installing front brakes...
Old Aug 7, 2016 | 09:53 AM
stocker77's Avatar
Ok guys, need help with an issue I created for myself being stupid.
Got new front rotors, pads and titanium shims. I installed the parts and the front right pads and shims where too tight. It kept the front right wheel from turning.
After the install I left the car up on jack stands and started the car and put it in first to see if I could get the front right wheel to rotate. I eased off the clutch and heard a clunk and immediately depressed the clutch and shut it off.
Now I have a ABS & AWD system service warning. I removed the sims to free up the front right wheel and started the car and put it in first again, but the damage was already done.
Curious if anyone has any experience with the abs & awd system that could tell me possibly what could have happened and needs to be repaired.
I need to find a good Mitsubishi shop to fix this issue, so any recommendations are much appreciated. I am in the Northen Kentucky area/Cincinnati Ohio area.
Thanks in advance!
Kope
Old Aug 7, 2016 | 10:24 AM
migs647's Avatar
What level is your brake fluid at? If it is for some reason low after the toggling of pads, you'll get that abs warning.
You should easily be able to run new pads, rotors and shims as long as you press the pistons back into the caliper and it not mess up the ABS system.
Old Aug 7, 2016 | 10:32 AM
stocker77's Avatar
I am running the motul rbf600. I'm not low on fluids, it's just throwing up the ABS & AWD System service required warning. It happened when the front right wheel was locked. Wonder if it's as simple as resetting the warnings?
Old Aug 7, 2016 | 11:25 AM
splattj's Avatar
Check all the wiring for the front ABS sensor on the side that went clunk. Could be that it got caught up in something and damaged.
Old Aug 7, 2016 | 12:51 PM
stocker77's Avatar
Thanks, did another visual check for any damaged sensors.
Disconnected the battery for 15minutes and still didn't clear the abs and asc codes.
Also figured out what the clunking was...I didn't tighten the rear lugs since it was still on jack stands.
I got everything tightened up and decided to take it for a drive to see if the codes would clear up from actual driving. Lucky for me the codes cleared up after driving it down the road. I guess I was just way too paranoid about messing it up!
Thanks for helping me trouble shoot! Feeling relieved now. Hahaha
Old Aug 10, 2016 | 08:36 AM
Veronica's Avatar
Makes sense. The ABS sensed the one wheel not turning and triggered the event light.
Old Aug 10, 2016 | 10:37 AM
ChipperEvo's Avatar
was just going to try suggesting clearing the code and see if it comes back.
glad it was nothing.
foxbat
Evo X How Tos / Installations
Nov 7, 2011 06:29 PM
Massimo Power
Evo 'For Sale' Suspension / Brakes / Handling
18
Nov 7, 2008 07:37 AM
BoostIt
Aug 17, 2008 02:00 AM
MREvOTard
Feb 7, 2008 08:55 AM
beebers
Dec 15, 2004 10:26 AM
