Sponsored by:
Sponsored by: CARiD
Power Steering Noise on 2011 EVO X
Old Aug 31, 2016 | 10:07 PM
irwintan27's Avatar
So after changing the clutch and got everything back, the PS started making noise. The noise started after 30 mins of test driving the clutch. The weird sound only comes every time the steering wheel is turned and goes away when the steering wheel is not being used. Can anyone chime in?
Here's the video
HTML Code:
https://youtu.be/maDQiVrjuwk
This is when the steering wheel is turned left to right and vice versa. Sound disappear when the steering wheel is on the center.
Old Aug 31, 2016 | 10:35 PM
Biggiesacks's Avatar
I just had to add some power steering fluid to my 2011 MR because it was a bit low and making noise on left turns. Have you checked your reservoir?
Old Aug 31, 2016 | 10:37 PM
irwintan27's Avatar
I'll check it again.
Old Sep 1, 2016 | 08:06 PM
irwintan27's Avatar
So I checked it and its on max. I noticed that the noise starts coming out after the car has warmed up.
Old Sep 2, 2016 | 02:57 PM
hoobastnk90's Avatar
Maybe bleed the power steering system?
Old Sep 2, 2016 | 03:35 PM
ZLAYER's Avatar
Use a turkey baster to remove the old fluid, replace with new fluid. I used royal purple, which worked great. Noise was instantly gone. After you fill it with fluid ( with front end jacked up) turn the steering wheel lock to lock ( I believe with the reservoir cap off) several times to bleed out air.
Old Sep 8, 2016 | 01:22 PM
irwintan27's Avatar
I did this and you're right, the noise instantly went away! I went with the AMSOIL PS. Thanks a lot!
Old Sep 10, 2016 | 06:19 AM
ZLAYER's Avatar
Super, glad to help! At first I was paranoid my whine noise was t-case, but I figured out that it was just when I turned left. So I took it to the dealer, and they thought it was a bad wheel bearing (they were wrong). So YouTube videos made me think it was the PS, and that nailed it, much to my relief!
true4nae
16
Nov 10, 2014 09:50 AM
xXANCHORMONXx
Aug 7, 2014 08:23 AM
Jesussaves1
22
Aug 17, 2013 07:33 AM
GoEVOGo
Aug 14, 2005 03:02 AM
evo_ik
Mar 18, 2005 02:51 PM
