Sponsored by:
Sponsored by: CARiD
More Power!!
Old Dec 8, 2016 | 01:56 PM
evostanman's Avatar
Originally Posted by joonvang
So than do you guys agree that I should forget the mods I listed and just do a E85 Conversion with a tune? And than have the MODs I listed added on later down the road?
Just add the E85 set up to your mod list.
Wouldn't Gas mileage go down since E85 tend to burn quicker?
Yes.
These cars are horrible anyways when it comes to that.
Smiles per gallon is how I see it
Old Dec 8, 2016 | 02:15 PM
joonvang's Avatar
[QUOTE=evostanman;11690743]Just add the E85 set up to your mod list.
I'm trying to determine what I should do for the time being. Either buy all of the parts that I initially stated or go with just the e85 conversion for the time being as it would cost too much to do all of it at once. If you were given these two routes, which one would you go with considering that you want to go with the route that will give you the most gains.
Old Dec 8, 2016 | 02:32 PM
ddlopresti's Avatar
If you are going to do it in two steps it won't make much of a difference, with the mods you are thinking about going E85 I would think would add more gains. Razorlab has a thread about basic bolt ons vs e85, so check that out.
Old Dec 8, 2016 | 04:32 PM
roidz3's Avatar
Definitely go with e85 the car really comes alive and you'll never wanna go back to regular pump gas! been running it for over 2 years myself.
Old Dec 8, 2016 | 06:53 PM
Lightsaber's Avatar
Originally Posted by migs647
I'd avoid the HKS BV. They don't scale well. (This is coming from a big HKS fan)
What is then an ideal BOV for bolt-on Evos? Just the Tial?
Old Dec 8, 2016 | 10:49 PM
roidz3's Avatar
Synapse DV
Old Dec 9, 2016 | 01:22 AM
Dross99_si's Avatar
Originally Posted by roidz3
Synapse DV
This
Old Dec 9, 2016 | 08:03 AM
AustinMac's Avatar
+1 on the E85. 105 Octane = More boost and less knock. Plus it burns colder. More Power = More Smiles as stated above. I also think of the gas mileage thing like this. If i put E85 in one of my cars.. I know im going to be on it all the time. If i put 91.. Meh i might be a little more conservative on the pedal. Probably not but with all potential in the E85 might as well use it!
Old Dec 9, 2016 | 11:14 AM
evostanman's Avatar
[QUOTE=joonvang;11690750]
Honestly if money is an issue I would just save until I have enough to cover everything because If you do it in 2 steps you're going to be spending more at the end.
Remember that adding parts to your car like 3-port will require a tune. Tune + parts = $
if you stock pile parts and save money you can knock everything out in 1 step.
If you decide to go with the least expensive side first, you're still going to need a tune. Then after you go with the expensive mod, it'll require a re-tune
Old Dec 10, 2016 | 04:55 AM
Dross99_si's Avatar
[QUOTE=evostanman;11691028]
Words of wisdom right there.
Stockpiling parts will save money in the long run as well as save you on trips and downtime. Do it once and do it right.
Also, plan for the long term. If you ultimately want a complete big turbo kit, don't buy a bunch of bolt ons now only to be dissatisfied and have to replace everything later.
Identify your goals, do your homework, take your time and do thing right.
Maximum Output
42
May 24, 2010 11:30 AM
shiv@vishnu
213
Aug 5, 2005 03:05 PM
bluebanana23
Jul 11, 2005 04:55 PM
