Sponsored by:
Sponsored by: CARiD
High fuel pressure
Old Jan 18, 2017 | 05:45 PM
kevin salazar's Avatar
High fuel pressure
so I just installed a new return fuel line to my ams fuel rail cuz it was leaking after I installed I saw my fuel pressure regulator gauge was excessive high now and a lot of white smoke coming out the exhaust
so what can be causing this? And how to fix this problem?
Old Jan 18, 2017 | 05:51 PM
LetsGetThisDone's Avatar
What fuel pump and wiring are you running? What is your base pressure, and did you adjust the regulator?
Old Jan 18, 2017 | 05:54 PM
Just a 255 walbro pump and I was at oem pressure at 42 psi all I did is change the line that runs from the fuel rail cuz it was bad
Old Jan 18, 2017 | 07:18 PM
RazorLab's Avatar
What's the pressure now?
I wonder if something is stuck in the line...
Old Jan 19, 2017 | 07:43 AM
six40's Avatar
White smoke is coolant though, so I wonder if that is another issue as to why you're burning coolant...
Old Jan 19, 2017 | 08:04 AM
Veronica's Avatar
Nope - I would wager it is crimped and that white smoke may be (unburned) fuel...
Check your install again.
Old Jan 19, 2017 | 08:09 AM
Yea the car been sitting in my garage for like 3-4 days with the line off till yesterday when I installed it and saw my pressure gauge really high but I'm going to check the install today again after work
Old Jan 19, 2017 | 04:04 PM
4b11slayer's Avatar
I agree with the smoke possibly being fuel, when it doesn't fully burn and a lot is being dumped it in fact it blows white ish smoke.
Make sure there isn't a bend somewere in the line.
Im guessing the car runs like crap now?
06EvoIXmr07
Jun 20, 2016 08:01 PM
03lances
Lancer Engine Management / Tuning Forums
Apr 17, 2010 12:28 AM
colo_evo
Dec 30, 2007 08:20 PM
EVO MR FU
Nov 15, 2005 05:09 PM
edtxag
Jul 31, 2004 09:14 PM
