Sponsored by:
Sponsored by: CARiD
Anyone ran with an RS?
Old Jan 26, 2017 | 06:17 PM
  #61
DBomb117's Avatar
Originally Posted by blueblursti
https://youtu.be/1l0fkixoaz8
right near the start the fronts spin and the rears take a while to spin.
lol wtf
Old Jan 27, 2017 | 01:12 AM
  #62
Robevo RS's Avatar
Originally Posted by kyoo
I'm in agreement with you lol. I'm just saying what they're saying (they're very defensive about their car).
that torque steer likely comes form the front wheels only getting the power, before the rear wheels come into play. in motion, I'm sure its a different story
here is how a proper AWD should work when its slipping or have no traction.
You see how well the front and the real works together, there is 0 delay between axels which it shouldn't be. That is the key for good handling lesser reaction times between axels, and power distribution on axels.
No delay gives you more precise feel, and control, its simple is that.
https://www.youtube.com/watch?v=bXHRWidW6bM
https://www.youtube.com/watch?v=22g6sxUfT94
Old Jan 27, 2017 | 03:21 AM
  #63
moparfan's Avatar
where's the video?
one of the car's better claims is that its always driving the rear wheels, as opposed to a haldex which is only part-time
Plus there is a minimal radius of operation below which it is ineffective.
Old Jan 27, 2017 | 04:58 AM
  #64
BlueBlurSTi's Avatar
One huge issue the ford and Honda I vtm 4 & sh awd have is that they cannot send power to the rear at a stand still. The ford and Honda require power and grip to the front in order to send it to the rear. This Honda system "can send 70% to the rear" but it does this at a loss by stealing from the front and wasting power in the clutch clamping process, then pukes the loss through the overdrive unit. (2.7% in I vtm-4) this can only be accomplished in certain circumstances and a certain speed. It is only used to help yaw the car for a very brief moment. I guess what I'm getting at is that they sacrifice a ton of power weight and complexity to attain a very brief lack of understeer. In effect these systems should not be thought of as awd but yaw assist or torque distribution systems. They aren't always engaged, they are native fwd.
If you are stuck or in a straight line or at the wrong speed or not doing the right thing at the right time they will not work, they are only designed to work under certain parameters.
https://youtu.be/KzQKjQR9u0A
The Lancer evolution 50:50 full time with variable 100-0 center lock system plus 9 generations of lancer evo R&D. Suspension geometry, chassis everything comes into play when actually putting the car around the corner. The Evolution X system is complex yet simple in its execution and tuned very well.
The super AYC is another amazing bit of engineering, using planetary gears as well as clutch packs to shuffle power.
Subarus STi awd has a slight rear bias but it's a great always on system. I would always get more wheel slip in my old STi than in my Lancer Evolutions. The DCCD center diff is a very brilliant bit of engineering.
Old Jan 27, 2017 | 06:43 AM
  #65
kyoo's Avatar
I don't think they were ever considering a "traditional" awd system though. It sounds to me like they were basically going to go with haldex, but then wanted something better. good for them on that, at least.
explain - not well versed in mechanics
I think they can take off with rear power from a stand still, but it is dependent on programming entirely. their launch mode starts with power to all wheels
Old Jan 27, 2017 | 07:26 AM
  #66
it has to receive a clamp to get power to the rear perhaps the launch mode tells it to clamp upon the gas pedal being pressed or something like that.
again how much goes to the rear and for how long is all random depending on the gear, clamping pressure and what the ecu thinks it should send depending on the situation. If the system gets too hot it will shut down the rear all together.
Old Jan 27, 2017 | 07:28 AM
  #67
Robevo RS's Avatar
I am fine and happy the way as the RS came out, I would still buy it over the STI. There is no power or handling problem with the car really. In fact as a stock car vs other stock cars, puts competition behind herself.
But here is why I wont buy the car and I said it from day one.
This is an RS, so from here
and from here
how the hell they ended up here
Old Jan 27, 2017 | 07:36 AM
  #68
kyoo's Avatar
the links are broken, can you repost?
I do like the RS, I really do. but I don't like how exclusive it is. looks are ok in black white or gray, the blue is a little too flashy for me. it's also a little pricey, and suspension seems to stiff for daily stuff.
I'd really love the hatch sti for a daily if 1) the engine weren't a timebomb and 2) the mpg weren't so bad (I know, I know)
Old Jan 27, 2017 | 07:39 AM
  #69
government regulations and mass sales. if they would have made a lightweight aluminum car with a robust but loud and expensive awd system, it wouldn't sell. The focus RS is largely a parts bin car. I really hope they make the next gen platform with the RS at the core and do it right.
Old Jan 27, 2017 | 07:43 AM
  #70
Robevo RS's Avatar
hm for me is working , please let me know if it still broken
Old Jan 27, 2017 | 08:02 AM
  #71
kyoo's Avatar
rob - may just be my work filter. i'll take a look at home
Old Jan 27, 2017 | 08:35 AM
  #72
Pics look great on my end
Old Jan 27, 2017 | 11:04 AM
  #73
Napalm_Enema's Avatar
Guy posting about too stiff suspension on an EVO board. Much LOL to be had
Old Jan 27, 2017 | 11:25 AM
  #74
kyoo's Avatar
yup, I've got ohlins and they rock. my back thanks me
Old Jan 27, 2017 | 01:09 PM
  #75
moparfan's Avatar
A stock Evo X is pretty plush coming from 14 years of daily driving a 94 Miata R..
