going E85 (flex fuel)
going e85 and looking for plug and play e85 kits. came across this one
https://www.maperformance.com/produc...map-evox-400fk
worth it?
and these for flex fuel
https://www.driven-fabrication.com/p...-flex-fuel-kit
or
https://www.delicioustuning.com/EVO-X_Flex_Fuel
thanks
worth it?
or
thanks
Get the flex fuel setup from flexconverter.com. That's what I run and it's flawless. You don't need the map kit. Just get a ASNU E85 fuel pump and either ID1050X's or ID1300's depending on how much power you want to make. I suggest the 1300's. Aside from that you'll need to get a hold of the TephraX3 rom
https://flexconverter.com/products/b...x-fuel-package
is there a huge difference between 1050 and 1300s? power wise just want to be around 400hp/350tq currently at 340/340.
the TephraX3 rom is it needed? or can my tuner run their own?(if theyre able to).
Thank you, this is the flexconverter right>
[QUOTE=e_kobz;11739231]yup thats the one. if 400whp is your goal then the 1050X's will work just fine. TeprhaX3 with flex is the only oem ecu flex fuel option right now unless you're planning on going stand alone[/QUOTE
oh understood, did not see this while researching.
I'm already tuned on open source, so i should be able to DL this from evo scan site and then my tuner can set the tune accordingly.
sort of how it will work right ?
[QUOTE=TheIndianGuy;11739268]
Pretty much. Just to clarify you are wanting full flex fuel correct? not just two seperate maps?
[QUOTE=e_kobz;11739269]
yes, that's correct. I want full flex fuel. Don't want two separate maps.
Not a lot of e85 stations around me or on my commute to work. So full flex fuel is the best option.
Many have used WTF flex kit.. This is just flexconveter kit, but it has all parts that you need for flex. You can read e85 via Android App.
https://www.wtftuned.com/collections...ex-fuel-system
DF kit is pretty new in market, good thing it has gauge.
Forget about delicious kit, many tuners already said their kit isnt great.
Do research on the flexconverter kit first! The wait times on that thing can be pretty significant so if youre looking to have the kit in hand immediately, double check first! Make sure it is in stock! I ended up cancelling my order from flexconverter after waiting a couple months and bought the drivenfab kit which arrived at my doorstep in 2 days. The DF kit comes with everything required as well.
Either way, good luck!
i did come across the wtf kit but wasnt sure about seemed similar to the flexconvert kit
wait time isnt an issue right now as im planning this for mid summer or so while i gather other parts. exhaust is next thing but seems like it wont make a big difference power wise.
but i will check with FC to make sure wait time isnt too crazy.
Thank you!
WTF kit is the flexconverter kit but $40 more expensive. The driven fab kit is nice, I just did not want an extra gauge, but that's just me. A quick log on my phone and I'm content
I think there was more in that kit... damm i cant remember. All i know is WTF only uses their electronic.
99gpgtx
20
Mar 23, 2017 06:07 PM
formerSTIowner
Apr 30, 2014 09:11 AM
boostedwrx
Mar 26, 2011 10:05 AM
