Sponsored by:
Sponsored by: CARiD
Car won't start after replacing all possible parts
Old Nov 22, 2017 | 03:20 PM
jsdude's Avatar
I have a 08 evo x with built engine. One day the car just die on the highway, it won't start. I got it tow to the shop, when the car arrived to the shop, it starts again. First thing it came to mind must be the fuel pump. But I replace the fuel relay first, which it doesn't work. I order an arm fuel pump which is what I'm currently running. It still won't start, the spark plug got oil bathed, so I replaced them as well. I check the oil line to the engine to see if there was any gas oil going into the engine, which was fine. I then replace the crank position sensor, the car finally runs. But 2 days later, the car won't start again. WTF, anyone know why?
Old Nov 22, 2017 | 05:41 PM
RazorLab's Avatar
Why is the spark plug getting oil on it? Only a couple ways that would happen, and all of them aren't good.
Have you done a compression and leak down test?
Old Nov 22, 2017 | 07:54 PM
jsdude's Avatar
Compression test and leak down won't effect the starting. Two reason that will affect starting of a car, ignition and fuel. I replace all of them, that's why I stuck.
Old Nov 22, 2017 | 07:58 PM
RazorLab's Avatar
Welp, sounds like you have all the answers, good luck!
(pssst. spark plugs aren't supposed to ever have oil on them, that has nothing to do with ignition or fuel)
Old Nov 22, 2017 | 09:25 PM
LetsGetThisDone's Avatar
Omg
Old Nov 23, 2017 | 06:17 AM
AJV's Avatar
AJV
Old Nov 27, 2017 | 11:55 AM
Veronica's Avatar
(pssst: oil-fouled plugs are hard to start )
Old Nov 27, 2017 | 06:14 PM
►EvolutionX◄'s Avatar
lol, engines don’t need compression to start? You ask for help then tell people they are wrong for helping you diagnose your problem. Just so you know, you’re wrong.
Old Nov 27, 2017 | 06:27 PM
Biggiesacks's Avatar
sounds like you need to replace the operator.
for real though, you need to upgrade your humility module if your going to be asking for help on the interwebs.
Old Nov 28, 2017 | 06:23 AM
Twylyt's Avatar
+1
You need four things to get an engine started/running. Fuel, Spark, Compression and good timing. If any one of these is off, then you'll have issues. Good luck.
Wmu240
Dec 18, 2015 10:18 AM
Wmu240
Sep 4, 2015 07:02 PM
Dann
Aug 26, 2011 07:05 PM
Kyle R
Jun 11, 2007 11:55 AM
Z_Lancer_Man
Lancer Troubleshooting
12
Jul 13, 2004 01:32 PM
