Sponsored by:
Sponsored by: CARiD
Won't start. Seeking insight.
Old Mar 13, 2019 | 12:28 PM
CaptainCrunch's Avatar
Hi guys. 2015 GSR, Roughly 45k miles. Late 2014 build. Basically stock. Sat for 2 days, garaged in NJ. Cold at night is about 30 degrees. Car cranks.. all lights, alarm, radio, headlights work. I disconnected negative terminal on battery for 15 minutes, tried both keys, and its still a no go. In the past, I found sometimes I would go to start the Evo and it would turnover, but barely. It was almost as if it wanted to die immediately but never did.
Any ideas? I have roadside coming to attempt a jumpstart. And I guess if that doesn't work I have to tow to a NJ Mitsubishi dealership which I have had no luck whatsoever with. Any ideas would be really appreciated. Thanks.
Update: Roadside came and got it going. He kept cranking while tapping the gas. Eventually it started making a different sound and fired up. Ton of smoke out the back end. He said maybe the starter or fuel pump?
Update Update: No clue if this is anything or just some road trash I ran into. haha
Old Mar 13, 2019 | 02:07 PM
Napalm_Enema's Avatar
When did you last replace the fuel relays?
Old Mar 13, 2019 | 03:02 PM
Never, I believe. Truthfully, I never even heard of them being a maintenance thing.
Old Mar 13, 2019 | 03:32 PM
Blue_Lion's Avatar
Old Mar 13, 2019 | 04:38 PM
Hey, thank you! You think thats the source of my issues? How difficult is this install? How often do you recommend these get swapped?
Which set should I get? The MAP one has 4 relays.. doesn't say which. And the Kozmic has 5.
Old Mar 13, 2019 | 06:49 PM
Stupid easy - plug and play - I'd try that first then go further with things. Get a few of them since so cheap in case you need in teh future.
Old Mar 13, 2019 | 07:27 PM
Awesome. Thanks so much! Can I ask.. which set should I buy? How many do I need in one set of swapping? One has 4 the other has 5. I assume they are different types.
Old Mar 13, 2019 | 07:44 PM
I'd hit up Kozmic and ask them, they would be able to better suggest than I. Give them a shout tomorrow good bunch of guys.
Old Mar 13, 2019 | 08:19 PM
Blue_Lion's Avatar
I know it says kozmic has five but I read in another forum that it ended up coming with four as well. So I would also say to definitely ask and confirm. Even if that doesn’t solve the problem, you’re pretty much solving another that can potentially cause you to be stranded miles away from home waiting for a tow. No one wants that. Good luck!
Old Mar 14, 2019 | 12:23 PM
Got it. Thank you!
Good info. Appreciate it. I will contact them and report back. Thanks again!
Old Mar 14, 2019 | 03:27 PM
DesertDog57's Avatar
Sounds to me like you had a flooded engine judging by the ton of smoke coming out. I had the same problem recently but mine was flooded so bad it fowled my spark plugs and tainted my oil. But the dealership dried out the cylinders and got it started with a bunch of smoke coming out. My flooding was due to starting the car and then turning it off right away, apparantly evos dump a bunch of gas in to start up and you have to let it run for a bit or else it will flood. If you press the gas pedal to the floor and hold it there before you turn the keys to start it, it will enter a clear-flood mode and cut all gas to the engine. Alternatively if you aren't getting enough fuel due to "winter gas", you can turn your key on and off to prime it.
Old Mar 14, 2019 | 08:05 PM
Whoa, really interesting. Thank you. I know for a fact before I last drove it and shut it down for that two or three days, that I had started it up in my garage for a few seconds and just turned it off without driving it. Interesting that this happened to me right after I did what you mentioned. And thanks for the what to do tips in case I run into such scenarios in the future, very very helpful.
Old Mar 14, 2019 | 10:08 PM
Can you gentlemen clarify this for me please.
maperformance has a TSB linked showing this below. It shows 4 relays being replaced. Then a popular forum shows earlier Evos needing a separate relay replaced. I have a 2015.. should I do all 5 of these? What havea you all been doing? Its not about the money.. its more about not doing something I shouldn't. What has everyone done? Thanks.
Old Mar 14, 2019 | 10:30 PM
TurboTJ's Avatar
I had the exact same thing happen at 43k miles on my 2013 MR. I called the dealer and planned to get it towed.
Heres what I was instructed to do and it worked perfectly.
Get in the car and hold the gas pedal to the floor. 100% pinned down, not half throttle. When the ECU sees 100% throttle, it will shut off the injectors and let the gas clear the cylinders. After cranking it for a few seconds, stop, give it a sec, and then start it normally.
Old Mar 15, 2019 | 07:20 AM
Awesome DesertDog I'd forgotten about your issues when Captain had his. That's more than likely the culprit good call out!
