Sponsored by:
Sponsored by: CARiD
what do i need to do on my evo x
Old Aug 19, 2019 | 09:38 PM
Kai Man's Avatar
hi, i just brought a 2012 evo x
i wanna do all the maintain servies on my evo ,
like engine oil , transmission oil , tranfer case oil, rear diff oil
what else should i change ?
thank you guys
Old Aug 20, 2019 | 05:06 AM
ugakirk's Avatar
Congrats on the new car.
That's a good start. May be a good idea to replace the relays and possibly spark plugs if it hasn't been done before.
Old Aug 20, 2019 | 06:33 AM
White2015evo's Avatar
I just had my tranny done gear box done and a oil change. Depending on what type of antifreeze you have , it typically becomes acidic after about 6 or 7 years so make sure you flush that out when needed. Or you'll end up with problems years later from it eating up seals and such. Plugs and wires is good start to the addition you and I have both listed. Take care of that care and it will last you! How many miles do you have on it atm.
Biggiesacks's Avatar
brake fluid, Inspect pads and rotors, rotate tires, check alignment (as in look at the tires, not take it to a place, unless it needs an alignment) intake air filter, cabin air filter.
Old Aug 20, 2019 | 09:28 PM
Chubey16's Avatar
When ever I get a new to me vehicle I like to Change:
Engine Oil.
Engine Oil Filter
Transmission Fluid
Front Transfer Case
Rear Diff
AYC fluid (EVO)
Brake fluid Bleed
Air Filter.
In cab air Filter
serpentine belt (Accessories belt)
Check:
Brake pads, and soft lines
Power steering fluid
Coolant (see what mix it is. ex: is it 50/50)
The biggest thing I find is that you keep a log book of what and when you did it.
n52b30
Oct 25, 2013 01:25 PM
fafaforza
Oct 29, 2012 09:21 AM
denlin68
Aug 18, 2012 07:55 AM
lockadam2112
Oct 4, 2009 06:29 PM
EvoAlex48
32
Jun 27, 2009 03:25 PM
