Sponsored by:
Sponsored by: CARiD
camber and toes?
Old Sep 20, 2019 | 09:34 AM
Markelov's Avatar
camber and toes?
Recently, I damaged my front suspension on a ****ty road so I changed my OEM suspension to Ohlins R/T and planning to get alignment.
Do you need to change camber and toe when you get a new suspension?
Old Sep 20, 2019 | 11:30 AM
CaptainSquirts's Avatar
Yes. It'll all go out of whack if changing suspension parts, especially struts/coilovers.
Old Sep 20, 2019 | 11:31 AM
Biggiesacks's Avatar
You can have them use stock settings when they do the alignment, or you can go more aggressive if you want. It may just come down to what they can do, because the range of adjustment might only allow for certain combinations.
Old Sep 20, 2019 | 12:18 PM
LetsGetThisDone's Avatar
You will need an alignment. If you set the Ohlins up as recommended in the instructions, you should be able to get aligned pretty close to factory specs. Most tire wear is caused by incorrect toe settings, so a little extra camber is fine.
Old Sep 20, 2019 | 07:32 PM
Markelov's Avatar
Ok, I went to the dealer today and they put it like this. Is it ok?
Old Sep 21, 2019 | 01:31 PM
That's fine. But the car would handle better with 2* camber up front.
Old Sep 21, 2019 | 02:44 PM
GTA.RS's Avatar
Seeing as you know where the front toe is now for zero, if you drill a tinny countersink mark it would be a good reference mark
To make it 4deg total toe out up front for a keener tracky day, rotate the arms 3/16" 4mm (to be shorter)
You can always return back to the marks after the tracky day
That's so long as you don't alter the front height. If you do, the marks will be wrong
AF13_Evo
Mar 12, 2018 06:49 AM
jr-mack
Oct 18, 2014 03:11 PM
Darkrider3
12
Apr 5, 2011 02:52 PM
NYrEvolution
Apr 16, 2006 07:11 PM
EVOSTEVO
10
Nov 10, 2004 11:50 AM
