Sponsored by:
Sponsored by: CARiD
Evo x won’t turn over
Old May 8, 2020 | 05:16 PM
jay99's Avatar
Hey guys , won’t turn over . A slight click and dim dash lights . However battery seems good .
tried to upload short vid from my phone.. not sure it uploaded though
Old May 9, 2020 | 01:13 PM
jay99's Avatar
So today I checked volts to the starter 12.5 or so. Shorted out the starter it spins up but doesn't engage. When trying to start it from inside car it just does a click and a small other sound and thats it. Suggestions please
Old May 9, 2020 | 01:40 PM
Biggiesacks's Avatar
Probably a bad starter. Maybe some lost teeth on the flywheel, you could try spinning the motor a bit by hand and see if it will crank after.
There is also the old smack the starter with a hammer and see if it works. That's a sign the starter is going bad if it does.
Old May 9, 2020 | 04:10 PM
jay99's Avatar
I removed the starer , is there any tests I can do with it out? Also I only have my fast fob. If the key lost the coding etc , could this be a result? Thx
Old May 9, 2020 | 05:57 PM
jay99's Avatar
I tested starter works good, reinstalled it. Took the starter relay out and wire jumped it. Engine turns over now but does not start.
Old May 9, 2020 | 11:54 PM
roidz3's Avatar
Try checking relays first especially if they haven’t been changed. If not check fuses and tank of fuel pump. I had a bad pump before cause the same issue your having. Key fob is also something to check if you have a second one with a new battery.
Old May 10, 2020 | 12:50 PM
jay99's Avatar
All Figured out , thanks guys !
Old May 10, 2020 | 12:53 PM
THR_Evo8's Avatar
Well? What was it?
Old May 20, 2020 | 06:41 PM
jay99's Avatar
Well , I checked the relay. Took it out did a manual starter relay jumper test turned over but didn't start. Checked the fob out, opened it up cleaned it out took battery out and tested it then put it all back together and tada!
SkippygoluckyIV
Nov 13, 2015 03:31 PM
cal1mr
13
Feb 3, 2015 01:46 AM
Kealinstillz
Jan 14, 2015 10:06 AM
bumblebee04
Mar 11, 2010 08:59 AM
