Sponsored by:
Sponsored by: CARiD
EVO X GSR 2015 not making compression
Old May 21, 2020 | 02:44 PM
Drareg Ramos's Avatar
Hey guys pleased to meet everyone 🤙
so imma start saying that my knowledge for Evos are really slim that’s why I’m trying to get as much info as I can before I move on so please let me apologize for my ignorance in advance.
Now, I’m trying to see if you guys can help me out trying to guess what really happened to my engine.
Here’s the full story..
I was gonna take my car to the mechanic to get my oil pan resealed because I have a very small oil leak coming from it. When I was about 2 miles away from the shop, low oil pressure pops up on the Dash. So I stopped and put 1/4 of oil to it, just enough to make me reach the shop. I turn on the car, the light comes off and everything sounds good so I continue the trip. 30 seconds later the car turns off on me while I was driving (no warnings ⚠️), I go and buy 5 quarts of oil and put em on (didn’t check how much I had since it showed low oil pressure). I try to turn on the car and it wouldn’t turn on. I get the car towed to the mechanic and when he checks the oil there’s actually 11 quarts on it. 5 from the oil change, 1 from the low oil pressure and 5 after the car turned off on me while I was driving it. He drains it down back to 5 and turns it on and he hears the rod knocking noises. The next day he turns it on again and the engine sounds normal, no sounds out of the ordinary. He tells me to drive it and see what happens. I go ahead and change the oil again and oil filter (check for any metal pieces or sparkling fragments on the oil but it was really clean/clear. I turn on the car for about 10 min let warm up and it’s sounding normal, I take it out to test the engine running and 10 seconds later it turned of on me while it was running. The car it’s cranking it’s just not turning on and I got the battery checked and voltage it’s on the normal voltage.
Thanks in advance for the suggestions and options
Old May 21, 2020 | 10:08 PM
JDZNate's Avatar
Veteran: Air Force
I would find a mechanic/shop that specializes in Evos in the Las Vegas area and have the car towed to them.
Maybe try the regional section for a shop. https://www.evolutionm.net/forums/we...hread-935.html
Old May 22, 2020 | 05:38 AM
I’m calling people to see
Yeah this is my 4th day of me trying to find someone to repair my engine
Old May 22, 2020 | 07:23 AM
Biggiesacks's Avatar
for next time it might be wise to check your oil level with the dip stick before just dumping in 5 quarts. The fact that you got an oil light and you weren't low is probably not good. Have you checked the compression as per your thread title? If so what were the numbers? What did the spark plugs look like? If not, I'd say pull the spark plugs and see what they look like. If they are covered in crap you could try throwing in a fresh set and see what that does.
Old May 22, 2020 | 09:30 AM
RazorLab's Avatar
Who the hell dumps 5 qts of oil into a car without checking the current oil level? Holy cow.
Old May 23, 2020 | 05:34 AM
whtrice's Avatar
Veteran: Air Force
Old May 25, 2020 | 02:20 PM
I already said excuse me for my lack of knowledge, I assumed the car had no oil
since the light came on the Dash.
Old May 25, 2020 | 02:22 PM
I get better help saying what can I do now it’s instead of bashing or making fun. 🤙
thanks
Old May 25, 2020 | 04:39 PM
RazorLab's Avatar
That's low oil pressure, not low oil.
Old May 27, 2020 | 06:03 AM
ugakirk's Avatar
1. I think you should stop working on your own car.
2. Get car towed to tuner, hopefully Evo specific, and have them look over the car.
Maybe this place? http://www.allaccesstuning.com/all-a...g-engines.html
I don't know. Never been out there and can't remember any big shops out there.
Old Jun 3, 2020 | 12:02 PM
Thanks, BTW in not working my car
thanks
Old Jun 3, 2020 | 06:50 PM
Jaraxle's Avatar
My co-workers wife called him and said the "gravy boat light just came on".... I almost died..
Then I told him it's called the "replace engine light"... No one laughed after that...
Old Jun 4, 2020 | 09:08 AM
RazorLab's Avatar
"Gravy boat light"
lmaooooo
kosteniuks17
Jun 3, 2014 08:02 AM
RallySport9
Jul 12, 2012 12:52 PM
mattgood2
Jul 22, 2009 07:33 PM
Derek888
16
Jan 12, 2006 09:24 AM
skrib
Jul 1, 2004 01:09 PM
