Sponsored by:
Sponsored by: CARiD
Did a boost leak test need help??
Old Jan 14, 2021 | 07:02 PM
jrsimon27's Avatar
Hi did a boost leak test in my MR the thing is that i put 23psi of boost and to my surprise never had that happen the oil dipstick flew off the whole engine bay got full of oil. Then went ahead cleaned the mess and to my second surprise started the car and a ton of smoke was coming out of the exhaust checked the spark plugs they are fine iam at lost what could this be? Thanks
i drove a couple miles and the smoking just stopped.
Old Jan 21, 2021 | 06:39 PM
six40's Avatar
Did you disconnect the vent hose going from the intake pipe (pre-turbo) to the valve cover first?
Old Jan 22, 2021 | 12:30 PM
jrsimon27's Avatar
nop
Old Jan 22, 2021 | 12:48 PM
Biggiesacks's Avatar
You should be removing the intake and testing it from the turbo inlet. The intake pipe is not meant to see boost.
Old Jan 22, 2021 | 12:55 PM
RazorLab's Avatar
You pressurized the crank case, because the vent hose from the intake to the valve cover goes to the crankcase.
Either disconnect that hose (and the boost solenoid hoses and BOV tube) and cap the nipples or take the intake off and attach the tester straight to the turbo
After your fun event, I would also check that you didn't blow the turbo oil return line o-ring (where it goes into the block) or you are going to have an oil leak.
Old Jan 24, 2021 | 09:20 AM
jrsimon27's Avatar
thanks for the tip will go check it out.
Old Jan 24, 2021 | 10:08 AM
jrsimon27's Avatar
just checked the oil line behind the block no leaks thanks razorlab.
Old Jan 24, 2021 | 01:44 PM
RazorLab's Avatar
Good to hear. Your dipstick saved that probably.
FYI, I had my dipstick shoot out mid 3rd gear pull. My PCV valve failed and pressurized the crankcase, basically what you did. All of a sudden oil all over my windshield. I thought the motor blew. Made a HUGE mess. I had no towels with me so I had to use my shirt to wipe the oil off the window so I could drive home. lol
I think I am still finding oil in the engine bay two years later from that.
Old Jan 24, 2021 | 08:49 PM
jrsimon27's Avatar
Wow i hope that never happens to me my heart would stop jajjaa will change the pcv valve as a preventive measure.
Old Jan 25, 2021 | 07:36 AM
RazorLab's Avatar
To be clear, it wasn't the OEM PCV that failed, it was a crappy aftermarket one I had used for my catch can setup at the time.
Old Jan 25, 2021 | 07:57 AM
jrsimon27's Avatar
Oh ok thanks for sharing.
wwevo9rs
Jun 3, 2020 04:52 PM
Keith B
Jan 28, 2020 11:53 AM
dgutierrez079
Jan 16, 2018 08:18 PM
Mikey15
Mar 26, 2013 12:36 PM
jxs1984
Aug 18, 2010 03:45 PM
