Sponsored by:
Sponsored by: CARiD
Hand-made front lower control arm bar
Old Jan 23, 2021 | 12:28 AM
Zijie He's Avatar
Lightbulb Hand-made front lower control arm bar
Continually worked on my car during the holiday season and finished the front lower control arm bar.
I am trying to replica cusco one, but it's hard to do so without welding and properly bending. So I tried my best to make a workable version with less effort and no deletion or modification to the existing components.
The final version looks like this:
And the undertray can still fit after removing four clips at the rear end, I used two zipties to mount it to the brace.
The clearance should be kept unchanged, since it's not the lowest part.
It's basically a square.
With two spacers and fittings to bolt on the lower control arm.
Also some adjustments to fit into the position.
Since it's exposed to the elements, it needs to be properly painted with rust proof.
The plate mounting the lower control arms has tons of holes to bolt on the entire thing.
Old Jan 25, 2021 | 09:27 AM
ugakirk's Avatar
Ha I want to see what you've come up with this time. But the pictures aren't working for me.
Old Jan 25, 2021 | 12:02 PM
Zijie He's Avatar
LOL, I can never upload the attachments correctly.
Old Jan 26, 2021 | 05:06 AM
splattj's Avatar
You're not far from a decent looking piece! I applaud your efforts given what you have at your disposal. Trim/grind away the parts that stick out past where they need to and then take it someplace to have it all welded together. Then you can ditch the bolts too!
As it sits, if there's any actual load on that brace, the bolts won't be enough to keep the brace from shifting which will negate its purpose. Welding it up/having it welded will make it far more functional.
Old Jan 26, 2021 | 08:02 AM
six40's Avatar
Agreed, have it welded and cleaned up. Looks good though, I love when people take the time to
make stuff instead of just buying everything out of a catalog
Old Jan 26, 2021 | 08:47 AM
Biggiesacks's Avatar
Another masterwork by user Zijie He! I could tell as soon as I saw the two duct taped bars that this piece meant business. You even painted the duct tape! What incredible attention to detail. Most people would look at this and think "that has the structural integrity of a wet cardboard box" but I want to commend you on the true genius of this ballast adding piece of art. Bravo sir, I look forward to your future endeavors.
Old Jan 27, 2021 | 09:21 PM
Zijie He's Avatar
Some updates after several-days driving, since the two shorter / driving-direction bars have not been bolted on to the subframe or welded on to other pieces, they may randomly vibrate like crazy. I tend to believe they do not provide extra stiffness as the lower control arms and the bushings won't hold strength in the direction. So I just deleted them.
The bars actually made a quite noticeable difference, especially after the installation of the rear strut bar.
It's definitely better to have it welded, but a welder seems too much for me to invest. Maybe I can try low temperature welding rods or jb weld next time. I am not too concern about the bar itself though. The joints are built by 1/2 in tube and 3/8 in bolts, their combination should be even stronger than the 3/4 square tubes. (I am not an expert here, just a very random guess. But in general, the bars are extremely over-engineered.)
The duct tape - indeed the water proof tape, serves the purpose to prevent water from entering the square bar. The rear bar needs to be cut some 1/8 thinner to fit the subframe.
Old Jan 28, 2021 | 04:42 AM
splattj's Avatar
It's not a complex part or a lot of welds. Just sand down the joints you want welded and then you can get someone at a muffler shop to weld that up for you for $20-40. Alternately, beginner fabricators and side-job types put their services up on Facebook and Craigslist all the time.
Old Jan 29, 2021 | 09:38 AM
Zijie He's Avatar
Oh, that's interesting, will take a look.
Old Jan 29, 2021 | 10:31 AM
Absolute "E" for effort but as noted, those hinge points are just that! Not to mention the fastener rust that will take place
If you want a lower bar, Cusco, Carbing & others make them.
Its my opinion that you will not / cant notice the difference between having one or not. If you were tracking heavily i could see installing one but if youre just DD'n & HPDE then one will never notice the diff
Old Jan 29, 2021 | 11:46 PM
Zijie He's Avatar
Making turns at 40+ mph
impact blue
Sep 28, 2013 11:40 PM
Buschur_TSI
Mar 8, 2009 04:40 PM
ashun22panda
Jan 29, 2008 09:16 PM
scb1999
Apr 18, 2006 10:59 AM
