Sponsored by:
Sponsored by: CARiD
Steering shaft problems
Old Apr 24, 2021 | 11:30 AM
Juli10's Avatar
installed the front sway bar. After I got the car completely back together, i looked in the foot well and realized during our work the sub frame had pulled the inner steering shaft completely out!!! with effort I could slip the two back together. Currently the steering wheel is crooked and I have the warning lights for the S-AWC (AYC & ACD) on! Please help
Old Apr 24, 2021 | 04:14 PM
splattj's Avatar
You got the shaft back on without the wheels being straight. Either you need to remedy that or the steering angle sensor needs to be recalibrated. I'd try to get the shaft off again and straighten the wheels/steering wheel before putting it back together, If you fix it by adjusting the tie rods and recalibrate the sensor, the light will go off but the range you can turn the wheel in each direction will be uneven.
Old Apr 25, 2021 | 01:33 AM
Juli10's Avatar
so the wheels where straight but the steering wheel wasn’t when I reconnected the shaft. Is there a way I can remove the steering shaft so I can straighten it without having to drop the sub-frame ?
Old Oct 9, 2022 | 05:06 PM
ghost1face's Avatar
How did you fix it? I just did something similar I suppose 🤦‍♂️
kngnothg
Oct 4, 2011 12:01 PM
TJPhillips36
May 2, 2011 04:21 PM
Werd
Dec 17, 2009 06:46 PM
triguy
Aug 30, 2009 09:15 PM
