Cylinder #3 Ignition Coil burning hot even with car not running.
I ran into an issue with my 2008 Mitsubishi Evo X GSR yesterday. The car was having a bad misfire on cylinder #3 and had to limp the car home. I went and checked all of the spark plugs and everything checked out okay but when grabbing the coil pack from cylinder 3 it was burning hot. Cylinders 1, 2, and 4 were all capable of being pulled out without burning my hand. I checked the car this morning and grabbed a new ignition coil and placed it in the car and with just the ignition being on I heard a crack and instantly turned off the power to the car (pictures attached of ignition coil). I looked at the wiring for the cylinder 3 and everything checked out to be okay. Im stuck and have no idea what else to try. If someone could possibly help out that would be amazing. Thank you!
I just placed a new ignition coil into the cylinder and even with the new coil it was heating up and getting hot. Could it possibly be an issue with wiring or something?
Ok after I posted what I said I feel kinda stupid. The coil is getting hot not what is in the cylinder. As biggie said maybe a fault or something like that or maybe a power wire getting to much power to that coil.
I would take a meter to it and check voltage to the first coil and then to that one and try to trace it back to where your getting the same voltage and go from there. Maybe you tapped something into the the circuit that goes to that coil. Tough to say
Checked out all the grounds on the car and everything came out good. Still confused on why the Ignition coil is heating up and getting hot to the touch? Talked to my tuner and he has np clue but we will be trying to figure out the issue as well. If there is any other suggestions that would be great help. Thank you.
A ground fault is when a circuit is shorted to ground where it shouldn't be. Think sticking a fork in a wall socket. You have just become a ground fault.
The way the ECU triggers the coil to activate is by sending it a momentary ground signal. This is called active low. If there is a ground fault on the signal wire of the coil (or in the ecu etc), it could cause the coil to be stuck trying to fire. I'm sure there are a million videos on youtube on how to use a test light or a meter to find ground faults, so I'd recommend you look there for instruction. I don't know what's wrong with your car, but this is one of the first things I would be checking for.
