Sponsored by:
Sponsored by: CARiD
DRIVETRAIN PROBLEM! dealer?
Old Mar 16, 2022 | 10:02 AM
JDMV8's Avatar
Hi guys.
A couple months ago, I had a drivetrain fluids service at a dealership A (tranny, t case, rear diff etc). Yesterday, I heard a loud clunk/pop while on the highway followed by "disconnecting" of the drivetrain. Throttle input would raise RPMs but power would not be put down. Initially thought it was the clutch. Clutch pedal works normally and all gears 1-5+R work normally. The car is "stuck" and has resistance to move any distance forward or backwards while on all 4 wheels. Had it towed to the nearest mitsu dealership and they found that the drain bolt from the front diff is missing.
Original dealer claims they didn't drain the front diff. But isn't the front diff in the same housing as the t case? Just trying to find out if the dealer A touched the bolt which drains the front diff. And also if I should be worried about any other part of my drivetrain. The car had to roll a bit to be towed and it rolled a bit on the highway before I safely stopped on the side of the road.
Old Mar 16, 2022 | 10:21 AM
Biggiesacks's Avatar
There is a transmission drain, and a transfer case drain. If they aren't talking about the transmission, then its the Tcase. Off the top of my head I can't remember if the diff is in the trans or tcase for the X. I'm pretty sure it's inside the Transfer Case though. If you lost all the tcase fluid and it seized, then you are probably looking at a replacement tcase.
At any rate the dealer who did your service is either completely incompetent, or is playing games with you.
Old Mar 16, 2022 | 11:38 AM
RobbieOh's Avatar
5 Year Member
On the X, I don't recall see a "front diff" drain bolt, it's likely the t-case mitsubishi dealer B is talking about. Do you have pictures? either way if it's the trans or t-case bolt and you have receipts that they serviced both, hold them accountable.
Old Mar 17, 2022 | 08:22 AM
RazorLab's Avatar
On the 10, there are four drive train fluid drain/fill locations.
1. Transmission
2. Transfer case
3. Rear diff
4. AYC clutch pack
There is also ACD fluid but that is in the trunk and I doubt the dealer touched that.
Common mistake/issue is confusing the rear diff and AYC clutch pack fluids.
If your car can’t roll, then something is fried and needs replacing. Time to lawyer up.
Old Mar 23, 2022 | 03:56 PM
JDMV8's Avatar
It is the tcase plug. Dealer is not honoring fixing it and is denying all responsibility. Mitsu corporate isn't helping either. Will buy a tcase and have it built by shep out of pocket. Should I be worried about anything else?
Thanks for the replies, guys.
Old Mar 25, 2022 | 12:12 AM
Lightsaber's Avatar
Why don't you speak to a lawyer first?
Old Mar 25, 2022 | 08:54 AM
ViciousLSD's Avatar
I broke my ring and pinion and had to give it power several times to move the car out of the track, put on a flatbed/test rolled on my driveway, frequently encountering crunching metal bits... the tcase didnt crack but TRE said the pinion housing was out of spec so that cost me another $250. It's good to have a backup tcase, especially while evoX parts are cheap, assuming you plan to keep the car
Old Mar 26, 2022 | 06:59 AM
JDMV8's Avatar
Good to know. Thanks.
Old Mar 27, 2022 | 07:51 AM
kikiturbo's Avatar
I have seen the small teeth on the evo X Tcase input shear off, .... makes for symptoms identical to yours..
RiioT
24
Sep 30, 2016 02:17 PM
MitsiMadness
Jun 26, 2011 07:55 PM
ModenaTwinTurbo
18
Jul 6, 2009 10:20 AM
Team Purple
Jun 4, 2007 07:36 PM
Marcus84
47
Aug 21, 2004 04:38 PM
