Sponsored by:
Sponsored by: CARiD
60 month maintenance on low mileage car?
Old Jul 13, 2022 | 09:43 AM
TheHolyLancer's Avatar
Hey, I got a 2015 Evo X MR, and with all the covid and thus WFH, it hasn't even hit 25k miles yet but it it time for the 60month (well beyond it actually) maintenance.
I am wondering how long in terms of years do the things like the belts, the reserve fluids and etc. are supposed to last?
I have already done the TC-SST oil with diaqueen at 10k miles a couple of years before, so I am not worried about that one until it actually hit 25k miles (doing a 15k mile interval since all of the stories about it helping to not make the thing blow up), but I am worried about the plastic / oil being expired due to age on the other stuff.
And if I am doing the service, is OEM for the belts / oil the way to go? I know for TC-SST other oils may be as good, but the oem diaqueen seems to be the preferred option given how expensive it is when something goes wrong.
Anyone know?
Old Aug 10, 2022 | 06:52 AM
six40's Avatar
I would definitely stick with the OEM SAE90 in the Transfercase and rear differential and OEM Diaqueen in the transmission. However, things like belts - take a look at it. There’s a 99% chance it’s fine. If it’s not and needs to be replaced, any decent $25 aftermarket belt will do. Certain things I believe in OEM only and other things you’re good to do aftermarket, as long as it’s a decent product/brand.
Old Aug 11, 2022 | 06:17 AM
splattj's Avatar
You should do coolant and brake fluid as they break down over time. Especially the brake fluid as it absorbs moisture sitting still. I agree that if you do the transfer case and rear diff should use OE Diaqueen. I'd also look at your power steering fluid. Mine was nasty at 35k!
TheHolyLancer
Mitsubishi TC-SST Discussion
Aug 5, 2017 04:03 PM
evox34
Dec 17, 2008 08:37 AM
gobagheera
Apr 12, 2006 02:08 PM
chizcwish74
May 12, 2005 09:39 AM
fatalbert69
Apr 16, 2005 02:09 PM
