Sponsored by:
Sponsored by: CARiD
Service brake system
Old Sep 5, 2022 | 02:52 PM
kanovic's Avatar
Just put the car together. 2014 gsr and we keep
Getting BRAKE SYSTEM SERVICE REQUIRED.. we have double checked everything and no idea why it’s on. Evo scan shows no codes, pads are new, it has plenty of fluid. Anyone got any tips lol
Old Sep 5, 2022 | 03:26 PM
Possibly this here: (low brake fluid in reservoir)
https://www.evolutionm.net/forums/ev...red-light.html
Old Sep 5, 2022 | 07:04 PM
kanovic's Avatar
i wish that was it but it’s not. I even put a little over max and still nothing
Old Sep 13, 2022 | 12:55 AM
WillD_EvoX's Avatar
5 Year Member
Happen to me when I did mine a couple times. It’s the pads settling in or could be other issues. I would just keep driving it hopefully it’ll stop popping up while driving.
Old Sep 19, 2022 | 05:38 AM
kanovic's Avatar
so the car sat for two years. The rotors were “rusted” but the rotors and the pads were brand new. After I got it running with braiding the rust basically came off. I am wondering if that might have caused something. The pads had plenty of life left and I would hate to change everything and it not fix anything.
Old Sep 20, 2022 | 06:47 PM
crabs_mcjones's Avatar
Double check the connection to the fluid level sensor. Make sure there's no corrosion in the connector if it sat for 2 years. You can also check the switch for operation using a multimeter with continuity detection. The brake fluid level switch is normal when the following conditions are met: When the brake fluid level is above "MIN," continuity is detected; and when the level is below "MIN," no continuity is detected.
Old Sep 20, 2022 | 07:24 PM
kanovic's Avatar
the sensor triggers the light when the sensor closes the circuit.
We then used a short lead to jumper the plug but it did not change the service light or anything.
Old Sep 21, 2022 | 07:30 AM
ugakirk's Avatar
Maybe something like this?
https://www.evolutionm.net/forums/ev...011-evo-x.html
Old Sep 24, 2022 | 10:21 AM
kanovic's Avatar
Originally Posted by ugakirk
yea read that. Didn’t really tell me anything that I didn’t check already.
Old Sep 24, 2022 | 11:07 AM
Biggiesacks's Avatar
is the switch for the hand brake plugged in?
You might try a different scan tool too. Im not sure if evoscan can pull ASC codes.
Old Sep 25, 2022 | 05:36 AM
kanovic's Avatar
it is. I took the whole console out. I might try and jump the sensor but everything seems to work as should. Iv tried using a very fancy scanner my father in law has and it still shows zero codes
Old Nov 21, 2022 | 02:28 AM
alfredodemarcos's Avatar
bmxking45
Sep 10, 2013 02:02 PM
Litcandl3
12
Nov 16, 2012 07:03 PM
vic01
Mar 21, 2012 06:17 PM
CaptainAsia
Dec 23, 2010 12:14 PM
Gruppe-S
Gruppe-S Engineering - California
Jun 24, 2005 06:33 PM
