Sponsored by:
Sponsored by: CARiD
Oil Catch Can and SMOG testing in TX
Old Sep 23, 2022 | 07:02 AM
bamburi's Avatar
Hi to my EVO lovers - have a question for you?
I am thinking of installing a MAPERFORMACE Oil catch can on my EVO X, but I have read that you can fail your SMOG test because of it. Has anyone had a SMOG test done in Texas and had any issues with the Oil Catch Can?
Thanks in advance,
Farouq
Old Sep 23, 2022 | 07:34 AM
Spooled_IX's Avatar
I live in CA, the strictest emissions state and I've passed numerous times with an oil catch can. The catch (pun intended) is that it must be plumbed in-line the OEM routing of the PCV system and not vented to atmosphere like the one you have pictured. I would still check TX's PCV emissions rules, but I doubt they are any different or stricter than CA's..
Old Sep 23, 2022 | 08:12 AM
L888Apex's Avatar
What part of Texas? Because only major cities in Texas require smog testing (in case you aren’t moving to a big city)
Old Sep 23, 2022 | 08:44 AM
RobbieOh's Avatar
5 Year Member
You could always temporarily replace the filter with a line back to the engine, so it's a closed system, then smog, then switch back to VTA, if necessary.
Old Sep 23, 2022 | 10:06 AM
ViciousLSD's Avatar
Using inspection shacks, only my driver door gets opened to plug in the OBD2 cable (some cant drive stick). If system is ready then youre going to pass. Tinted front glass, black taillights, uber loud exhaust might get some scrutiny.
Old Sep 24, 2022 | 07:25 AM
bamburi's Avatar
I am in Frisco (Collin County) - which does require annual SMOG tests from what I read. I've gotten some responses that most technicians won't look under the hood. Let's see once my SMOG renewal comes up in Jan'23....
Old Sep 24, 2022 | 07:26 AM
bamburi's Avatar
I've done only a few upgrades - such as replaced the upper intercooler pipe, cold air intake, short shifter.....so basics....that won't draw attention, but will give the Dodge Chargers in TX (plenty of them here) a run for their money
Old Sep 24, 2022 | 07:27 AM
bamburi's Avatar
I was thinking about that as a backup plan....thanks for the info....appreciate it...
Old Sep 24, 2022 | 07:29 AM
bamburi's Avatar
I actually moved from CA to TX in the past year.....it's such a difference....the 70mph speed limits just means people are driving at 90.....which I absolutely love. Chased a few Dodge Chargers doing 130......those are beasts for sure. Will check on details behind TX PCV emission rules....thanks man...
Old Sep 24, 2022 | 09:04 AM
ViciousLSD's Avatar
Just go to to the simplest shop with the least traffic. When I had blacked out taillights and florida-tint on my wife's car, they just tell me to come really late in the afternoon
Old Nov 23, 2022 | 01:33 AM
harryowen's Avatar
Old Nov 25, 2022 | 09:50 PM
ViciousLSD's Avatar
In Texas the car only needs all OBD sensors to be in READY state. One sensor not-ready would pass also
Visual inspection is for tint and lenses
jakgal04
Jun 27, 2016 06:39 AM
ELamb05MR
Nov 25, 2014 12:45 PM
whoang40
11
Feb 15, 2008 08:32 PM
urslo4n8
22
Jan 14, 2008 09:24 AM
FQ600
10
Nov 23, 2006 05:47 AM
