Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
HOW TO: Install factory Navigation into a NON-NAV Evo 10
Old Mar 9, 2020 | 04:30 PM
  #196
Nast_Nas's Avatar
Originally Posted by HoodieWeather
I tried the unit but it has dead pixels, I was stoked. But. do these nav's have bluetooth? It not, I might just sacrifice and get the radio touch screen that does have bluetooth. I do have the aux plugs in my 2011 GSR.
Going to answer your question now. Since you have an 11-13 Mitsubishi model (these models have streaming bluetooth called FUSE), 08-10 didn’t. To keep this OEM feature you need the navigation model from a 11-13, which is the N-05 model part number is 8750a238. All you would need is the screen with the install kit(which includes the wiring), unless you get one with all the wiring, which isn’t that likely especially if you buy from ebay(you can get the actual screens from there), hopefully this answers your question. I previously did this in a 2013 I owned to upgrade to the OEM navigation, at the time I wanted OEM because all the features and etacs items you could control.
Old Mar 9, 2020 | 06:08 PM
  #197
HoodieWeather's Avatar
5 Year Member
wow! thank you ever so much for the info buddy.
I was going to say since this goes from 08-11 https://www.ebay.com/itm/08-11-Mitsu...EAAOSwU0VeSpmZ
Why wouldn't it work? since you stated earlier that the 11's and up have the Bluetooth capability. If that's right. the 08-11 should as well. since it ends on 11. But I feel like searching on eBay is going to be a challenge.
Thanks
Old Mar 9, 2020 | 07:11 PM
  #198
Nast_Nas's Avatar
That is the earlier n-01 model. Yes it will all fit. All the 08-13 they’re all interchangeable, but the differences between the years I mentioned is the bluetooth Fuse that’s why they have different part numbers, and if you look in the bottom right corner you’ll see the N model number.. 08-10 only had bluetooth for calls, 11-13 had bluetooth for calls and streaming music, called FUSE. That’s why there’s different part numbers and then if you look at the bottom right there are different N numbers. So if you install an earlier model you will LOSE your ability to stream music. That’s why there’s difference in pricing for the screen models bescause of the features and depending if they have wiring or not
Old Mar 10, 2020 | 12:46 PM
  #199
5 Year Member
Mind me asking what about the other radio units that are out there. that came with the MR cars as well.
https://www.ebay.com/itm/2008-2015-M...ty!06776!US!-1
Old Mar 10, 2020 | 01:08 PM
  #200
Nast_Nas's Avatar
What you have linked is for the 14+, they will not work plug and play as these are CANBUS, and if you install into you’re 13 or older your car and dash would go crazy lol. Another note that’s not a nav unit its just a for touchscreen display, where it could show your oem back up cam
Old Mar 10, 2020 | 02:18 PM
  #201
5 Year Member
Dammit! I did send you a DM!
Old Jan 5, 2022 | 06:24 PM
  #202
5 Year Member
Want to thank the users and the persons who have helped me get my nav installed. I did this about a year ago.. wanted to say thank you for all your help
vassili
19
Jul 11, 2011 03:32 AM
sofly1990
Jan 23, 2010 12:40 PM
karizma23
75
Sep 12, 2009 09:33 AM
i64X
62
Sep 7, 2009 05:59 PM
Hydrolikz
Sep 27, 2007 12:22 PM
