Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
mounting the license plate
Old Apr 27, 2008 | 07:32 PM
  #46
mksevo's Avatar
I will start working on a solution. maybe a bracket that goes underneath the front headlight and then hangs down. that would work and no cutting needed. some have already had the front clip off, just need to see if we can tie into something with a bracket.
Old Apr 28, 2008 | 10:45 AM
  #47
Jblade's Avatar
Originally Posted by mksevo
Here in TX the plates are aluminum so you better check yours out first. magnets wont be helpful.
Yeah, thanks man, I was going to involve some steel ( I believe IL plates are also aluminum )
Old Apr 28, 2008 | 10:48 AM
  #48
DirectorSe7en's Avatar
Exclamation
Originally Posted by Robevo RS
Functionality aside, that looks terrbile/tacky. It either needs to be off to the side, or not there at all.
Old Apr 28, 2008 | 12:11 PM
  #49
syr00's Avatar
What the heck was went with my suggeton of just using some large suction cups placed in the middle behind your licence plate in the front, and attach it to the bumper.
Old Apr 28, 2008 | 02:41 PM
  #50
Jblade's Avatar
^ suction cups eventually lose suction, at least the ones that are attached to my windshield do...radar detector, GPS, phone holder, etc
Old Apr 28, 2008 | 03:00 PM
  #51
Someone school me, does it count if your plate is displayed on your dash? Or does it HAVE to be on the front bumper?
Old Apr 28, 2008 | 03:19 PM
  #52
StevenStarke's Avatar
bumper only
Old Apr 28, 2008 | 03:24 PM
  #53
Jblade's Avatar
I think that it is state dependent and open to "cop interpretation" meaning if they feel like being a d!ck that day, they will
Old Apr 28, 2008 | 09:32 PM
  #54
victoramone14's Avatar
Well the oil cooler is in the other side.. also just take a look at you intercooler the plates doesnt even cover over more the 2 inches. so no you dont need to worry about cooling. If you need to do that, then that is going to be more than the license plate position issue.
take a look again :
you could always drill little holes on the plate itself for all the people that do not want to lose too much air. i mean little holes about 1/4" to 1/2" inch apart.
idk my suggestion im gonna do it!
EDIT: maybe a bad idea because it might whistle!
Old Apr 29, 2008 | 03:31 AM
  #55
Robevo RS's Avatar
i rather looking better on the show, like without plate and drilled bumper..... and also dont need a ticket ...
so its great! the plate looks bad where ever you put it
but this was a suggestion only ,you dont need to follow
If you have a better idea i'm happy to follow .
Old Apr 29, 2008 | 03:32 AM
  #56
Robevo RS's Avatar
i dont think you allow to modify the plate .
Old Apr 30, 2008 | 08:43 AM
  #57
CC16's Avatar
I've found a vovlo bracket works. If you drill 2 holes under the mitsu emblem into the charcoal grille piece you can mount it there. It sits above the intercooler, but below the emblem, right in the middle of the nose. Now, that could be deemed tacky or appearance killing as well. I havent drilled mine yet, for that reason, but its a good alternative. You can probably rig it without drilling too, but thats for someone else to fabricate. Personally I think 2 holes in the front garnish is better than the holes in the bumper. Your car, your call.
Old Apr 30, 2008 | 01:16 PM
  #58
the intercooler blocking that little bit of the intercooler isnt hurting it all. theres also a good 6 inches of gap between the intercooler and plate so air definitely makes its way behind the plate.
Old Apr 30, 2008 | 02:11 PM
  #59
Robevo RS's Avatar
yes you are right ,
well some people try to make it perfect, and then they find themself, kinda lost in details... who,cares if you can take it off less then a minute and put it back a same time. specially if you have a stock car on the public road
Old Apr 30, 2008 | 04:16 PM
  #60
si_to_evo's Avatar
^just did the same thing
Thanks robevo
