Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Cone filter install - fixing the spinning bolt problem
Old May 25, 2008 | 09:26 PM
adrock1559's Avatar
I fell victim to the spinning screw that won't come out. If any of you are suffering from the screws by the MAF spinning and not coming out, try this fix. You will need:
A pocket knife, a flat bladed screw driver, philips screw driver, and a friend
The problem is the threaded metal fitting the screw fits into spins in the plastic airbox housing. To get around it, continue with the steps provided in cone airfilter install, and leave the back half of the airbox attached to the MAF. Once everything is removed, unplug the MAF and loosen the clamp behind it. This will allow you to pull both the MAF and airbox out of the car (making it easier to work on).
Once you have it out of the car, get a sturdy pocket knife and a flat bladed screw driver. Use the pocket knife to jimmy the bolt away from the plastic airbox flange. Then jam the flat bladed screw driver into the gap. Once you have done this, get your friend to slowly turn the bolt while you lever the sucker out of there. It takes a lot of force, and you will scratch the hell out of the bolt flange, but the bolt will slowly pull free along with the little brass fitting that was spinning in the airbox. I recommend unscrewing the bolt out of the fitting once you free it from the filter. vice grips work well.
This is the easiest way to get the bolt out without drilling. If you want to put the stock air box back on, just epoxy the brass fitting back into the airbox, and hammer it back into the hole you yanked it out of.
I hope this helps, let me know what problems you have.
Old Jun 12, 2008 | 02:43 PM
This_Guy777's Avatar
I had pulled on the airbox when this happened and the brass deal popped completely out of the plastic housing. Very impressive some of ideas engineers come up with when building cars.
DangerousDan
04-06 Lancer Ralliart How To Requests / Questions / Tips
24
Jun 1, 2017 09:07 PM
RallyDSM
Mar 19, 2017 07:05 PM
sabastian458
25
May 8, 2013 12:49 PM
mksevo
179
Nov 15, 2011 03:34 PM
EvoX-LI
16
Aug 28, 2009 02:55 PM
