Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
HID conversion on GSR non-SSS
Old Oct 1, 2008 | 06:58 PM
  #31
eclipsegsx012's Avatar
Originally Posted by mmartahus
Yup, I called my dealer and he said it would be about 3 grand to have them swapped out. He said it involved two new headlight assemblies, wire harnesses, a new ECU, and the switch that goes in one of the blanks next to the steering wheel.
Just curious why does it need new ECU? switch i could understand because you could adjust the headlight beam setting. I mean you could change the headlight connector to fit d2s and use the same headlight so do you really need wire harness or dealership is trying to make the money?
Old Nov 6, 2008 | 07:27 PM
  #32
Deannn's Avatar
can some tell me what an DRL is ? i got HID off my brother he bought it for his 300zx but dont fit.. they are 9006 soo i can just wacked them in ?
Old Nov 6, 2008 | 08:18 PM
  #33
Deannn's Avatar
ah googled it, Daytime running lights..
Old Nov 9, 2008 | 06:34 PM
  #34
jaymzlee's Avatar
can anyone tell me how to solve the flickering problem?
Old Nov 9, 2008 | 09:43 PM
  #35
socalevox's Avatar
im going to see if messing with the parking brake switch will solve it when i get my hid kit
Old Nov 10, 2008 | 05:01 PM
  #36
jaymzlee's Avatar
yeah its the parking break problem..
whenever i put my parking break down the hids flicker
its because there isnt enough voltage going through
it or something..
Old Nov 11, 2008 | 08:46 PM
  #37
TruboPower's Avatar
DRL's are high beams run at 35% output normally, so thats means the bulb is only getting roughly 4 volts, that would cause your HID's to not function
Old Nov 12, 2008 | 08:27 PM
  #38
eddielmc's Avatar
Has anybody installed SSS / MR Projector Headlight Housings on base GSR yet?
If yes, I would really appreciate a How-To on it
Thanks in advance
Old Nov 14, 2008 | 12:57 PM
  #39
lambtron's Avatar
I just installed the SSS headlamps on my base GSR. They are a direct swap, however, I still get the flickering issue. I think there might be a relay in the fuse box that the SSS model has that the base doesn't, but I'm not sure. I have the wiring diagram for the car, but I'm not the greatest at deciphering everything. Its annoying having to turn on the headlights during the day just to avoid the flickering.
Old Nov 15, 2008 | 01:31 PM
  #40
STItoEVOX's Avatar
could you link or upload the wiring diagrams? id really like to take a look at em. and whered you get the SSS headlamps and how much?
Old Nov 15, 2008 | 02:41 PM
  #41
jimm's Avatar
Cost?
Old Nov 16, 2008 | 05:42 AM
  #42
Deannn's Avatar
I wonder if you could put in couple of resistors ? :S
Old Nov 16, 2008 | 01:25 PM
  #43
STItoEVOX's Avatar
from what ive been hearing, i doubt that would work. wish i knew where to find the damn wiring diagrams for this car. anybody know?
Old Nov 16, 2008 | 07:51 PM
  #44
eddielmc's Avatar
Thanks for sharing.
Did you get the whole headlight assembly with HID or did you get your own aftermarket HID kit?
Old Nov 16, 2008 | 07:52 PM
  #45
eddielmc's Avatar
Thanks for sharing.
Did you get the whole headlight assembly w/ HID from Mitsu or did you get your own aftermarket HID kit?
