Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
HID conversion on GSR non-SSS
Old Feb 13, 2009 | 01:21 AM
  #76
kitw's Avatar
I've used the Apexcone/DDM tuning kit on a few other cars, and for the money, it really is great! (actually sheesh, I remember paying $400+ for a similar quality kit for my e36 M3)
Old Feb 13, 2009 | 01:42 AM
  #77
hybrid_r's Avatar
You can actually bypass the DRL's by using a relay kit. Use battery power to power the ballasts and use the parking lights as the signal to the relay to switch. This way, there are no DRL's. The only downside is switching on the parking lights and headlights will turn on your HID's.
Old Feb 13, 2009 | 04:23 PM
  #78
custm08's Avatar
I bought mine from ebay. A seller named sinomedia in Japan. $57.00 shipped. Whole plug and play kit. Look great! There are only two companies that manufacture the lights and ballasts so no matter wich ones you get, you're guaranteed to get something good.
Old Mar 4, 2009 | 09:02 AM
  #79
pltek's Avatar
if someone wants to swap their non-hids for my hids from sss, go here
https://www.evolutionm.net/forums/sa...r-non-hid.html
Old Jul 28, 2009 | 04:32 PM
  #80
d3zimus's Avatar
i have non-sss evo x,
i'm just confused as to what part i need for HIDz:
Composite assembly, lancer evolution, right, w/hid $662.99 each side
OR can I just get:
Composite headlamp, lancer evolution, right, w/hid $326.79 each side
I couldn't find any diagrams for either so I just wanted to be sure...
Thank you
Old Jul 28, 2009 | 04:36 PM
  #81
eddielmc's Avatar
You need the assembly ($663)
The headlights will plug n' play, however you'll have to leave your low beam on all the time or else they'll flicker.
As far as I know there are no known solution for non-sss to sss conversion
Old Jul 29, 2009 | 06:58 AM
  #82
ChinoBling's Avatar
If you look up jRox on these forums, he has a relay bypass that works to disable the DRLs and eliminate HID flicker. The best part is that it turns the DRLs off completely. So all lights off when you have them off. Parking lights only when you have them in the parking light position. HIDs/headlights on when you switch them on. It makes your lights work as it should have from the factory.
He made them for the regular Lancers and I just put them on my X this past week. Work perfectly.
Old Jul 29, 2009 | 09:34 PM
  #83
eddielmc's Avatar
Thx for the info. I tried to get the same relay from jRox but we concluded that it wouldn't work on a car swapped to factory projector (sss) headlights.
I'm assuming you have an aftermarket HID kit?
Old Jul 31, 2009 | 10:40 AM
  #84
ChinoBling's Avatar
Sorry didn't see that part. Yes I am using aftermarket HIDs.
Old Feb 11, 2010 | 05:12 PM
  #85
EVOXGEO's Avatar
Originally Posted by RpmSteve
you can use the SSS headlights, u just need to get an HID kit that does NOT have a rebased bulb. You need a D2S bulb with your HID kit
can u help me man , i have the sss package gsr, my whole complete headlight (rightside) went out and now i have to find a cheap fix can i disable the stock headlights balast and just install a aftermarket kit using just the headlights and not the stock balast? please man i know this is prob not the right thread but i need to find a solution asap thanx man .
jayt27
Aug 14, 2015 06:08 AM
b3n
Jun 17, 2012 06:10 AM
axtran
Jul 16, 2010 04:56 PM
jimm
Jan 30, 2010 01:32 PM
pd9000
Aug 28, 2009 06:26 PM
