Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
TPMS - Anyone know how to disable it
Old Jul 2, 2008 | 07:39 AM
nebolic's Avatar
was wondering if anyone knows how to bypass or disable the TPMS error light? Switched to aftermarket wheels but didnt port over the TPS.
thanks,
nebo
Old Jul 2, 2008 | 09:26 AM
EvoXstylin's Avatar
As far as I know your stuck with it. I bought new sensors for my aftermarket wheels.
Old Jul 2, 2008 | 03:23 PM
Slimdatwelve209's Avatar
how much was yours and where did you get it at cause im having the same problem too
Old Jul 2, 2008 | 03:35 PM
mksevo's Avatar
do a search on TPMS . someone had a simple fix with placing all three in a small 2 inch pvc pipe and the 4th on place on the pipe like in your rim. capped on both ends then fill it with air to 34 lbs and leave it in the trunk. simple , then change rims anytime.
Old Jul 11, 2008 | 03:09 PM
BluesunsXIV's Avatar
4th on place on the pipe like in your rim? not sure how to take that exactly, factory location on one wheel? it does sound genius tho lol
Old Jul 11, 2008 | 03:12 PM
Robevo RS's Avatar
as i remember it is not working for the X.
Back then was a zip tie solution, but that doesn't work either.
Old Jul 12, 2008 | 11:01 PM
DrasticK's Avatar
The tube won`t work. If the car isn`t getting the signal from the TPMS then the warning will be on. The TPMS are powered by kenetic energy, so they need to be in a rotating wheel.
Old Jul 16, 2008 | 08:27 PM
doclin's Avatar
any one knows if we can purchase a TPMS programming device....how much ?
Old Jul 17, 2008 | 03:15 AM
Papi4baby's Avatar
This is what the Tacoma guys are doing.
I assumed that the spare has a sensor too like Toyota's?
If so, once you get your new rims, have then pull the sensors and open up the spare, throw the sensors inside the spare tire and seal it back up with air. Should keep the light from coming on.
I guess secure them to the spare rim so they are not bouncing around freely.
Old Jul 17, 2008 | 04:45 AM
Robevo RS's Avatar
probably you didn't read this thread thru...
Old Jul 19, 2008 | 03:46 PM
Papi4baby's Avatar
I did, just offering advice for future people that will do the same thing. The only way for the OP if to purchase new sensors.
There's a guy in the Tacoma forums that broke the solder spot for the LED behind the TPS system. Had to take the whole gauge assembly off. And you would have to have drawings to find out which one it is, but is as simple is breaking the solder contact, or removing the LED all together(more involved).
Old Jul 19, 2008 | 09:03 PM
goevox's Avatar
i tried the sensors in the spare and didnt work...
Old Jul 20, 2008 | 05:05 AM
Robevo RS's Avatar
it is measuring the rotation off the rims... So you didn't read it thru just look it thru
Even if i accelerate hard, and the warning is not there anymore/disabled the yellow warning/ Will come back .
Old Aug 2, 2008 | 02:14 AM
robbie2883's Avatar
out of curiosity why aren't people just putting them in the new wheels? you can just take the sensors out of the stock wheels and put them in the aftermarket wheels. we've done it for over 3 years at our shop with no issues.
Old Aug 2, 2008 | 04:20 AM
is300's Avatar
the real ? to this is, can you do it with the tire on or not. if so how diffcult is it
