Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
disabling daytime running lights?
Old Jun 7, 2009 | 09:30 PM
  #46
slo4g63's Avatar
thanks for the deatiled pics and info on the non-sss DRL's.
Old Sep 24, 2009 | 09:34 PM
  #47
jlcamp7's Avatar
Alright so I don't wanna sound stupid, but I have everything I need and have created the bypass for my 07 Outlander LS. I don't wanna sound stupid here, but I wanna make sure I am doing this right. Where is the parking lot hot wire that the trigger wire goes to? and do I need to splice into it? Thanks
Old Sep 25, 2009 | 01:13 PM
  #48
Rican_GTS's Avatar
http://9glancers.com/index.php/topic,4231.0.html
hope that help you guys out!
Old Sep 25, 2009 | 01:31 PM
  #49
07outty's Avatar
.........go to the second page of the "how-to" forum.
read the how-to posted up by fusionchicken.
Old Sep 25, 2009 | 02:09 PM
  #50
boondoc's Avatar
Originally Posted by Rican_GTS
JRox already post this on here a while back.
Old Dec 28, 2010 | 04:43 PM
  #51
sdracer's Avatar
i need info on this as well i have everything down how you show and still nothing is it diff on the 2010
Old Dec 29, 2010 | 11:50 AM
  #52
BoostedSlvrGSR's Avatar
Im gonna feel like a noob asking this. When I pulled my headlights out to black them out, after reinstallation, my right DRL was not working, so I just unplugged the secondary wiring harness from the back of the headlamp to turn the driver's side off as well. The only thing uglier then two DRL's is one DRL.
I havent noticed any issues, only that the DRL went off.. my low beams and high beams work fine, blinkers too. Am I hurting anything with that unplugged?
Old Dec 29, 2010 | 03:28 PM
  #53
07outty's Avatar
you have SSS.
non-SSS do not have a dedicated drl bulb.
the drl is the headlight bulb operating at reduced voltage
Old Dec 29, 2010 | 07:50 PM
  #54
bao's Avatar
bao
dang, i bought an sss headlight but jrox's product cannot fix drl unless i changed to aftermarket bulbs. i gues id have to wait until mine goes out.
Old May 9, 2012 | 06:01 PM
  #55
Mex24x's Avatar
Hey on my 2010 GTS Lancer it was a simple fuse I figured out thru "all date" I just took it off n no problem cause I had HID fog's and stock 4100k or 4200k stock HID halogen lenses with the adjustable light height.
Any one know about a 2010 Mitsubishi Outlander,i think it's ES the very base model with hub caps lol
How do u take the Day Light's off. Is it a fuse just like the well 2010 Lancer GTS?
Old Nov 1, 2012 | 08:47 PM
  #56
xBY1993's Avatar
Hi. Sorry I'm a complete noobie. I recently got a 08 Lancer GTS. Trying to put on HIDs as my first "mod" lol. I've read a bunch on this but understand very little of what everyone is saying. I've seen 07outty's post on the fuse box, but I don't really understand what's going on. Could somebody please help me get started? Everyone needs to start somewhere right. Thanks appreciate it.
Old Jan 14, 2013 | 05:42 AM
  #57
lilmac789's Avatar
Help!!
Got my HID and trying to get those daylights off i went to my fuse box and where the DRL fuse is at theres no fuse there so how can i disable my DRL
Old Mar 19, 2013 | 02:23 AM
  #58
whitepanda's Avatar
Originally Posted by 07outty
inside the main fuse box there is a "finned" relay. that is the headlights.
i took a normal relay ( that is what you see with the 4 wires connected to it )
..and placed it in an open area of the fuse box.....it is NOT plugged in.
trigger wire goes to "parking light" hot wire
green just goes to chassis ground.
the other two will plug in to the two slots that the stock relay was plugged in to.
Thank you so much. I will try this today. If I have any questions, is it ok for me to PM you on it?
Old Apr 26, 2013 | 07:35 PM
  #59
RA173's Avatar
I switched from oem halogen to oem hid headlights. Does anyone know how I can get the drl to work properly on the new headlights?
my drl is still the low beam and the 1156 bulbs on the new headlights are off.
Old Apr 26, 2013 | 07:40 PM
  #60
wowitswil's Avatar
i believe u guys gotta run a bypass relay disabling it....cause on the non-sss version there are just a relay in the fuse box to disable them
