Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
fuel pump mod
Old Dec 12, 2008 | 11:48 AM
4myX's Avatar
fuel pump mod
if anybody is looking to upgrade to a walbro 255 pump here is a site with a foam pump housing, flex line, and hose clams which is the same set-up that ultimate racing is using. The only difference is ultimate racing dont use the foam housing they make a billet housing. I ordered all 3 parts for under 8.00 shipped.
Old Dec 12, 2008 | 11:51 AM
4myX's Avatar
sorry, here is the link . click on install parts http://apeusa.com/?6000
Old Dec 12, 2008 | 01:12 PM
allday10sec's Avatar
do you know what the stock fuel pump is
Old Dec 12, 2008 | 01:14 PM
hawaiian_evo's Avatar
Great Find I wonder how reliable it will be. If it turns out good I might just do the same.
what size pump sleeve did you go with?
Old Dec 12, 2008 | 01:25 PM
4myX's Avatar
no part numbers but here is what I got
Foam-Lg Thick Foam sleeve for fuel pum 1 $3.00
FlexHose Flex hose 1 $3.00
HC4 stainless #4 hose clamp 2 $0.60
im also using the stock filter on the new pump
Old Dec 12, 2008 | 01:31 PM
thanks for the answers you still gonna get the aftermarket fuel filterfrom UR?
Old Dec 12, 2008 | 01:37 PM
4myX's Avatar
as of now im not, it has the same protection as it was stock, but I may add a filter later down the road
Old Dec 12, 2008 | 03:07 PM
scheides's Avatar
EvoM Moderator
You sure that foam sock will be thick enough? The standard ones that come with the walbro kits would not nearly fill the void needed....if you make this work, TAKE PICS!
Old Dec 12, 2008 | 03:49 PM
4myX's Avatar
this is the largest foam sock size that you can get, it will be close to the same size as the stock fuel pump housing. The stock housing isn't a tight fit either. I bought this as a back-up because I did the modification to the stock housing to make the walbro pump fit and I didnt know if I would get it to work or not. So far I have'nt needed to do this yet, but I dont see having any problems with using this set-up
Old Dec 12, 2008 | 09:04 PM
Talon_66's Avatar
If you use this set-up let us know.
Id rather spent $8 on this, then $150
Old Dec 15, 2008 | 03:04 PM
4myX's Avatar
wow, I ordered my parts friday and got them by lunch today. Here they are, add a walbro pump and your set-up. Any questions on install look at ultimate-racing fuel pump kit it goes in just like it.
Old Dec 15, 2008 | 04:11 PM
4myX's Avatar
you can also use the stock filter so you dont need to buy one
rEvolutiondan
Aug 31, 2016 04:33 AM
1fastvet
May 7, 2012 10:19 PM
bmincey
Sep 12, 2008 10:38 AM
CaliMR
12
Nov 9, 2007 08:21 PM
